Locker Suggestions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cavalry, Mar 1, 2001.
  1. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I will be changing rear axles soon ('84 10 bolt to late model 10 bolt) I currently have a factory gov lock. When It works it works well but it has 100K miles and dosent operate as good as it should. I live in the snow belt and have heard horror stories about Detroits on slick roads. I have no need for a ARB in this truck. I am running a 350 HO and run it hard( probably have 33's soon too) so I worry about the weakness of "lunch box lockers" So whats everyones suggestion?
    Luke
    84 K5
  2. Cavalry
    Oct 1, 2000
    978
    Anyone?
    Luke
    84 K5
  3. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    My understanding is that one should run an open diff for safe driving on icy roads. If it were me, I would get a TracLok (that's what I have on both my front ends, and they are not a very aggressive limited slip). I don't know if they make a TracLok for your 10 bolt rear, but 4WheelParts carries all that stuff. If it were a dry climate, I would say shove a spool in there, but who wants to slide out and possibly crash? Ice scares me! I slow WAY down.
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Although I don't have first hand experience with them, you might try the TruTrac units. The are a torque sensing mechanical gear unit, supposedly work good and smooth, front or rear (wish they made one for my front Dana 60). A similiar unit is the Torsen by Gleason MFG, used in HMMWVs/Hummers (Front & Rear) some Audi Quatros, Toyota (supra, Rav4, celica), Ferrari. I can tell you this is THE reason HMMWVs have such good off-road abilities. 'Have only heard of one failure (in a HMMWV). Better biasing than the TruTrac although they had some reliability problems when coupled with really big tires (but can handle a good amount of horsepower).
  5. windrider
    windrider Registered Member
    Mar 3, 2000
    52
    Wisconsin
    I run a Detroit in snow country, Wisconsin, and I haven't had a problem. I think the the horror stories are from people who aren't use to driving in snow! I like the Detroit and I am thinking of getting one in my other truck too.
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'm in Minnesota and I have also heard the same things with posi/lockers. I have found I like posi much better in the snow and ice... much esier to get going w/ the spin wheel on ice. Not sure, but have driven our plow truck quiet a bit and it has a locker... seems to be fine, but haven't really road driven it much... but wow does she grip [​IMG]. I think I'm kinda leaning towards a powertrax at this time, but will probably wait till after the lift and new axles go in.
    1987 Chevy K5 Blazer- 350 TBI
  7. Cavalry
    Oct 1, 2000
    978
    The locker I run now has never scared me on ice. I just have heard of this(loss of control) as a Detroit specific thing. I have run LSD's and definately will go with a full locker. Any one just replace their old GovLock with a new one? Not too crazy about GM's prices most of the time (never seen them on the market) but its what I already run.
    Luke
    84 K5
  8. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    Eaton makes the Gov-Loc, and supposedly they have an updated version that is tougher and just all around improved.
    <A target="_blank" HREF=http://www.eaton.com>http://www.eaton.com</A>
    I'm also interested in the Zexel Torsen. I've driven many HUMVEE's and have never had a problem with them, reliablility or offroad. Sound interesting to me. I am still debating if I will eventually upgrade to a bigger 6 lug axle, or beef up my 30 spline 10 bolt.
    <A target="_blank" HREF=http://www.torsen.com>http://www.torsen.com</A>
    1992 Blazer Sport, 350 TBI, 4L60, 3" Flowmaster, K&N, 2.5" Rancho, 285/75R16 on 16x8 Baja's[​IMG]
  9. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    The Gov locs aren't the best to make an understatemnt. But almost all the new posi's in stcok F**ds, and GM are Eastons and are much improved.
  10. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    WELD THEM GEARS AND FORGET ABOUT IT!
  11. Cavalry
    Oct 1, 2000
    978
    I have lincoln locked before, spooled too. This is a 98% street truck not my wheelin truck. On road driveability is a must
    Luke
    84 K5
  12. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    From what I've read here and other places, the big winter problem with a Detroit Locker is that it locks up when you apply power (???), thereby usually causing the truck to push rather than turn. I've driven CUCV's with Detroit Lockers (the pickup-didn't know it was a Detroit until later) and on dry pavement, they always chirped a tire around corners and turns. Never noticed it when plowing snow on base with it, though. Personally, I'm going to go with a Detroit TrueTrac in back when I swap axles.
    [​IMG] Semper Maintenance!
  13. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    My brother-in-law just relaced his worn out gov-lok with an Auburn (cone clutches). He loves it on the street, but hasn't had it in the snow yet. It cost him $100 more than refurbing the gov-lok, and he feels it was well worth it.
