locker up front
Discussion in 'The Garage' started by bigblzr, Mar 6, 2006.
  1. bigblzr
    bigblzr Registered Member
    Jan 30, 2006
    17
    Thunder Bay ONtario Canada
    my friend and i were dicussing this the other day and we were wondering if the stock g80 locker out of a gm 10 bolt can be put into the 10 bolt front diff front as a cheap way to get a locker in the front.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    itll work
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have never really thought about it, but it would be rotating in the opposite direction, and the G80 uses centrifugal force to lock it.
    Wouldn't that keep it unlocked??
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have asked this same question here before and never got a satisfactory reply from anyone who has really done it.
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I have done it, and i can tell from experience, that it will suck, it doesn't really work, until you start spinning one wheel and then it will literally "bang" into engagement, puts alot of stress on that axleshaft and u-joints.
    I took it back out after the second time out trying it, and just opted for the Loc-Rite unit, AFTER i installed and removed the welded carrier,,,hated that too.
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The centrifugal force would be the same no matter what direction it was turning.
    If it would not lock up in the front axle, that also means it would not work in a rear axle when you were reversing........which is not true.
  7. readymix
    May 30, 2004
    6,706
    26
    Have you seen the inside of a gov-lock??
    What you said would be true if the locking cam had its pivot point in the center of its arch path......but it does not. It is set up so that a small amount of cent. force will have a large effect onthe carrier internals.
    Think of it as a lever, that's what it is. Now put that force on the other side of the lever.......what happens. Perhaps the same thing, but the force would not be multiplied......it would be divided.
    Thoughts.
