Locker Vs. Spool
Discussion in 'The Garage' started by thefarside, Dec 9, 2003.
  1. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    I was reading an article in the recent 4x4 Mag (forgot which one) and they compared the two. The spool won buy performance and price. Anyone have any thoughts as to which one is better?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Locker for us because spool is not an option unless you go D70 or are still stuck 1/2 ton.
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    IIRC, a spool is nothing more than locking the two axles together, and it never releases. A Locker like a detroit, will acutally release when not under throttle.
    Cheaper than a spool would just be to weld the spider gears.
    Same effect.
  4. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    Welding seems kind of hokey, cheap but still hokey.
    Maybe I am miss understanding what a spool is but this company seems to carry a large array of spools for different axles. /forums/images/graemlins/confused.gif Clicky
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    As was stated, a spool completly locks the axles. Never lets one tire rotate at a different speed while turning. A locker will dis-engage in turns to allow the tires to rotate at different speeds because of the radius difference. My friend totaled his Camaro running a spool when he broke an axle and the car dove off to to the remaining side during acceleration. You will wear tires much faster too unless you always drive in a straight line. Try making a u-turn with a spool. If your good, you can just slide it around otherwise that inner tire is going to be slipping and chirping.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    They don't make spools for a 14 bolt anyway, so it's a moot point.
    I have a locker in my DD and soon will have one in each end of my 'rig and I would not have it any other way. It's annoying sometimes, but well worth it.
  7. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    lockers click and clang around corners but for most people this is ok they would rather have the streetability of a locker rather than a spool.
    but with a spool there is never any doubt what is going on back there it is always engaged and doesnt have springs and other mechanical parts that can fail. I personally will only run a spool in the rear because my rig is strictly for offroad use and if someone is complaining because a spool wares your tires out faster then maybe they should just stick with open diffs and street tires for miliage I build an offroad rig to be just that off road. /forums/images/graemlins/thumb.gif
  8. 88Silverado
    Mar 13, 2003
    2,664
    For a strictly Off-Road vehicle then yes, a spool may be the best choice. I dont think he mentioned this was strictly a off-road vehicle therefore on the street, good luck with it.
  9. rvreddog
    rvreddog Registered Member
    Oct 14, 2002
    67
    San Antonio Texas
    I put a spool in the front of mine. I couldn`t justify the additional cost of a locker that does basicaly the same thing.When I unlock my hubs its like its not there,but when they are locked look out I`m going up and over! /forums/images/graemlins/grin.gif
  10. chubbybob
    Oct 18, 2002
    730
    there I go thinking for myself again I believe the question was witch is better. thats a hard answer but if you drive your rig a lot on the road and also wheel it sometimes. a locker would deffinitely be the best for you. a spool would ware on your rig more. /forums/images/graemlins/thumb.gif
  11. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I'm going to run a detroit in the rear of my rig (14 bolt) regardless of what's up front. However I am thinking of putting a spool in the front end since I run a lot of mud and turning isn't much of a concern. I did, however, buy an open diff. for my dana 60 that will accept the 5.13's I'm installing. It's useless if I go to a spool... hmmm... anyone want an open carrier for a dana 60 that will take 4.56 and up gears??? /forums/images/graemlins/rolleyes.gif
  12. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    ive got detroits front and rear and really couldnt be happier. even when the front hubs are locked, it doesnt seem to bind that bad on pavement. it seems like the driveshaft is takin more stress than any part of the axle.
    i guess it just comes down to whether or not your driving and what you need it for can justify the price.
    NITRO
  13. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    A spool has the same effect as welding your spiders, it's great for wheeling but sucks on the street. I welded mine and if it wasn't because my BFG's are getting chewed up at record speed I wouldn't mind. /forums/images/graemlins/tongue.gif
  14. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    (hijack)
    Bajaviking, how long has your rear axle been welded? I just got done welding mine (well NITRO did it /forums/images/graemlins/thumb.gif) and was just curious how long other people's have lasted.
  15. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    I was planning on having a strictly offroad vehical.
    I have two Blazers, so one for bling and one for wheelin'.
    The 86' for bling
    The 80' for wheelin
  16. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    (hijack)
    Yes, that woud be a good question. Anyone?
  17. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    As I was reading the article I started to wonder. With Detroit Lockers running from $300 to $500 each depending an application say vs. a spool for a D60 or Ford 9 inch priced at $190 each savings are substantial to say the least. So assuming a locker is basically a spool when locked then the performance off-road should be the same. So as with any 4x4 modifications each has its trade offs. Now what are they and how to decide if it is right for you? <---- This probably should have been my original question.
    Locker:
    Pro
    1) Ability to lock and unlock which prolongs tire life
    2) Does not put a much stress on the drive train as a spool?
    3) Available for a wider variety of axles types
    4) Turning is easy because of unlocking feature
    Con
    1) Cost!
    2) Ware out
    3)
    4)
    Spool:
    Pro
    1) Cost!
    2) Always a true 4x4!
    3) Less parts so less chance of breakage
    4) Easier to install??
    5) For that price some one could even carry a spare in the event of breakage
    6) Last longer because of limited parts
    Con
    1) Tire life
    2) More stress on drive train, maybe?
    3) Available for a selected amount of axle types
    4) Turning is difficult
    Welding:
    Pro
    1) Cheapest way to lock an axle!
    3) Easy/Quick modification
    4)
    Con
    1) Longevity of modification?
    2) Irreversible
    3) Botched welding job can ruin the entire axle assembly
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    spool and wleding spiders is meant for straightline driving,
    you will put more death to the tire on inside of every turn you take with a spool or welded spiders
    spools are for straight track vehicles
    if you trun such on pavement you will end up either breaking the welds or breaking a shaft and killing the tires because the inside tire will spin on every turn you take
    good luck
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lockers do not wear out. There is absolutely no advantage of a spool over a locker except price.
  20. thefarside
    Jun 27, 2003
    343
    Vernon, CT
    Odd, I thought anything that had movable parts would eventually at some point ware out because of friction and heat. I for the life of me cannot figure out how you can engage and disengage two axles without some sort of movement.
