Lockers for 1/2 ton
Discussion in 'The Garage' started by Cactus, Feb 6, 2006.
  1. Cactus
    Cactus Registered Member
    Sep 29, 2005
    5
    Arizona
    I want to put some kind of lockers in my 71 Blazer. The problem is that I don't want to do an axle conversion. I'm being told that the stock axles are to weak. However, I'm only running 33's. Whata ya think?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Put an aussie locker up front in the D44 but don't go larger than 33" tires. If you go bigger than 33 with a locker you better upgrade your front u-joints to spicer 760.
    If you go bigger than 35" I'd recommend adding alloy shafts.
    My 2 cents.
  3. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    I've got a detroit in my 10bolt rear, eaton posi in the front. All on 33" tires and on a suburban. I don't see a problem...
  4. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    on bc4x4.com a guy is selling front/rear 1/2 ton with arb lockers n compressor etc for 700 cdn, worth a shot
  5. Cactus
    Sep 29, 2005
    5
    Arizona
    Thank you Boy's. Lockers it is!
  6. 69TowRig
    69TowRig 1/2 ton status
    Dec 20, 2004
    288
    Raleigh, NC
    That 12-bolt rear will take quite a bit of abuse. I'd keep it if it was me.
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Question. Everybody says if you lock the front upgrade your U joints. In doing so doesn't this make the weak link in the front drivetrain move to the axle or ring and pinion? Wouldn't one be better off leaving the weak link as something cheap and easy to replace?
  8. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    dual lockrights. posi or arb if it see's a lot of road.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Az + 33's = Lockrights . I get on mine as often as I can . If your names not Rob , you can run without chromos . Just carry spare shafts , and don't be stupid when your wheeling :thumb:
  10. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I ran a locker in my 12 bolt with 35's for years. The front 44 should be OK, but it can brake. Tho you could brake just about anything if you try. :D May consider a limited slip or selectable locker for the front.
  11. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I would say it's OK, just don't go any bigger on the tires. I have 35's with a mini spool in the 10B up front. That's a little much for the stock shafts, 1 pinion yoke, and 2 axle shafts later I'm looking into cromo shafts for mine.
  12. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    The weight (width) also factors into the risk. LT235/85R16E (31.8 dia.) on 1/2 T Sub, LockRite in front, NoSlip in rear, corp 10Bs; no problems, yet.
  13. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    The only problem with that is when you do break/grenade a axle shaft u-joint it usually takes the axle ears off with it leaving you needing one or both of the axle shafts. Speaking from experience on this one.
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    dont think ull break a 14b shaft, but i might be wrong :haha:
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Theres a "kid" in AZ whos broken not one , but TWO 14b shafts . And he doesn't even really wheel :yikes:
  16. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    My current truck with 14 bolt is doing great. I was refering to back in the day when I had a 81 K5. I love seeing people around town with their purdy trucks lifted 12-16 inches with tiny 10 bolts or other weak open 1/2 ton axles, stock motor with flows and all kinds of chrome. Then I have my little truck with 35's and my big ol 14 bolt, everything scratched or rusted, 383 and locker. Ive abused 'er on the trail and on pavement. Shocked a couple ricers when I spun the tires and took them off the line. Al old Chevy's shoulda came from the factory with 14 bolts, enough lift to fit 35's decent gears and a rear locker. Blazer's, Trucks, 'Burbs.
  17. OffRoad
    Dec 8, 2002
    852
    you mean the kids who swaps motors like normal people change socks, and picks up chicks in his rock buggy? that guy?:D
  18. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I no notheeeeeen
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    oh ya i remember his post about them :haha:
    i like his dd buggy tho, thats sweet
  20. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    hmmm he must not have anything better to do...
    feel sorry for the guy...
