Lockers for 12 bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jmask, Feb 11, 2002.
  1. Jmask
    Jmask Registered Member
    Jan 16, 2002
    82
    Port Angeles, Wa
    I need to get better traction on the rear, I'm running 33/12.5/15's, with a corporate 12 blt, dana 44 in the front w/trac lk and 3.73's gears. I was told I had LS in the back when I bought the rig(then again-I was told i had 4.11 gears), I opened her up and found a carrier with 2 rods near the opening, one that had a little gear at the end lined up with a gear underneath the spider gear and a 1/2 inch log tab in the center. the oher rod had like a 3/4 inch long by 1/2 inch wide block in the center of it that would lock on to the other rod. I've never seen anything like it, maybe some one else has. My guess is that this is LS from factory.(?) Where could I get a good deal on a detroit locker for a 12 bolt? All responses welcome.
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Sounds like the Gov Lock (aka "The Exploder") on a Detroit, Drivetrain Direct, Randys Ring and Pinion, just compare prices and one will match the other. Beware of Drivetrain Warehouse. They are Four Wheel Parts Wholesalers in disguise.
    Depdog
    <font color=blue>Weenie K5, little mods' Small Tires!</font color=blue>
    <a target="_blank" href=http://depdogsk5.coloradok5.com>depdogsk5.coloradok5.com</a>
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Yup, it's a Gov Loc all right.
    Randy's Ring and Pinion might have a good used Detroit in stock for cheap.
  4. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    I just did this myself. after looking at choices and calling around I settled on buying a detroit EZ locker. its half theprice of a detroit locker which I was going to get but what I do in mine it will work fine for awhile. Randy's ring and pinion got my business. I didnt even have to work them for the best price.
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  5. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Blueknight,
    Don't go with the EZ Locker in the rear on the 12 Bolt. I put 2 in mine, and both exploded in the parking lot hill right after I installed it. I sent both back to Detroit and finally got a CLocker. I would advise against the EZ Locker in the rear. Just my .02 worth. Now when I got the C Locker, I have had no problems since.
    Robzilla
