lockers in 14-bolt?
Discussion in 'The Garage' started by MUD JUNKIE, Jul 22, 2002.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    anyone run a lock right in a 14-bolt?is this easy to install
    or shall i just weld it?if i weld it would a 6011 be a good rod?i have 50 pounds of that kind!!
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    If you are talking about a 14bff the only locking device I know of is a detroit other than a factory gov-lock.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you are just using your rig for off road and mud you might as well save yourself some money and just weld it.
    Heres a how to FYI : Weld 14 bolt info
    If you run on the street often you might want to go with a locker.
    Powertrax does make one for the open 10.5" 14 bolt FF and 9.5 "14 bolt SF axles. They are pretty easy to install. You just take out the spyders and replace them with the lockrite.
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Any warm blooded animal with a pulse could install a locker in a 14FF. I have ruined 3 sets of spider gears trying to weld them. I didnt do it like the tech article I tried to weld all of the seams and gaps and make it one big solid piece. Its like the heat warps the metal or somthing and I just cant it to fit back right, its tweaked out just far enough where the carrier wont fit back together.
    Setting the backlash is a breeze too...its that darn pinion depth that keeps getting me!
  5. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    yes,it the 14ff and there is a loc-right for this axle they sell for about 250 clams,ive put one in a 10-bolt before but i have never taken the 14-bolt apart so i dont even know how to pull out the carrier,what are the adjusting bolts?what do they do?
  6. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    There are the main caps like on all axles, then there are adjusting rings instead of shims. all you do is loosen the adjusting rings and the carrier pops out. Then take the ring gear off and the carrier splits in 2 pieces, there in the cream filled center is where you throw the locker.
    Check out this link
    http://www.off-road.com/chevy/tech/detroit/
    it has all the details.
    Brent
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    There are a few types of lockers readily available for the 14FF. The list goes like this:
    1. Detroit Locker
    2. Gov-Lock
    3. Lock Right (3 pin spider)
    4. Lock Right (4 pin spider)
    5. Soon-to-be-ready (I think) ARB locker.
    6. Of course, the famous "Lincoln Locker". /forums/images/icons/wink.gif
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    85mouse thanx for the article.well informative and when i get my detroit /forums/images/icons/laugh.gif ,i will know how to do it.
  9. Range Boy T
    Range Boy T Registered Member
    May 2, 2002
    21
    U.P of Michigan
    My self and my housemate both have a detroit in our 14bolts.
    It took about 1 hour to install. Very simple, very effective.
    Running a set of very bald swampers, the locker made up for the baldness. With a good set of tires, there is no stopping you.
  10. MUD JUNKIE
    Oct 24, 2001
    379
    Reddick,florida
    so the adjusting bolts hold in the carrier?or the caps and the adjusting bolts?what do you adjust?the backlash??
