Lockers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CBLAZER81, Apr 4, 2000.
  1. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    I just put a locker in and now it pulls to one side when I speed up and then pulls to the other side back out of it.I assume this is normal because my buddy's posi does the same thing.Is there anything i can do to fix this or just get used to it??
    Yes,I have driven over a F*&d lately!
  2. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I have Detroit Lockers in my 73 K5 and 86 K20 Suburban and neither of them exhibit any pull to either side.
    CB
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I would check the tires to make sure they have the same air pressure in them. Also measure them to make sure they are the same diameter, there is also a certain amount of tolerance in the manufacturing process which can lead to slight differences in overall diameter.
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I have a Detroit in the rear of my 74 K5, with a 14 Bolt GM Corporate Axle. It from time to time pulls from one side to the other when I let off the gas on the freeway and reapply gas. Just something you gotta get used to. Most important, pay attention when driving.
  5. cocky
    cocky Registered Member
    Feb 21, 2000
    88
    Northern Colorado
    I have a detroit in the rearend of my 70 k5 and when i hit the gas it pulls to one side or the other from time to time. Don't know if the locker is causing it though because i can't remember how it was w/o the locker
    Richard
    1970 k5 Blazer
    Don't stand in front of a train naked
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    I know my posi in my show car when I stomp on it. It does pull to one side then agina the the tires are a pure smoke cloud but I was under the impression in a Blazer with lockers you do not feel that much of a difference at least those are the people I have talked it. What type of locker?
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I have Detroits in two of my rigs. The one with the manual tranny pulls to one side or the other upon acceleration and deceleration. The auto euqipped truck does not pull at all.
    ken
  8. Crash90K5
    Crash90K5 Registered Member
    84
    Santa Clara, CA.
    I have 700R4 with a Detroit locker in a 14-bolt, pulls right on acceleration and left on deceleration. I have 2 full sets of tires and they have been rotated, so it's not tires. This did not happen with my 10-bolt and limited slip.
    [​IMG] <font color=blue>Crash90K5</font color=blue> [​IMG]
  9. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    I would imagine that if your rearend is pulling to one side when under acc. and to the other at decel. its because either your rearend is cock'd at a slight angle, or something is woreout. It could be something as simple as your spring pad's alignment pin being too large, to your u-bolts not being tight enough, all the way to your spring bushings needing to be replaced.
    Best of luck.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    http://www.geocities.com/corey_perez
  10. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    Thanks for the help.I'm looking toward the bad rear spring bushings.I've had a set for quite a while,guess i'll have to break down and put them in.I'll keep y'all informed as to if it works or not.
