locking a 14sf
Discussion in 'The Garage' started by jacksprat1599, Jan 1, 2005.
  1. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    I will be regearing the 14sf axle in my suburban and was thinking about adding a locker or Ls.Detroit is first choice but I have heard that they are very expensive for this axle.This truck is used for trailridding and camping only so with that in mind what other options do I have?Thanks
  2. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    carrier info
    check the side gear to carr play if keeping sf14 thay are known for chewing up carr assy. i have seen 5-6 out of 10 like this more commen on 88-up trucks.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    weld er up:xmas:
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I had 4.56s and a detroit in my '91 3/4ton sub with 9.5" SF rear. No complaints of having the detroit in the rear. It was kinda a piece of mind, didn't worry about it shocking the axles shafts like a gov-loc does when it engages.
  5. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    I don't want to weld it as its my dd and work truck.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ow I thought you said it was trail riding and camping only:xmas:
  7. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Add a lock-right then. $350, and a simple install.
  8. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    I did ,85 muddblazin,sorry for the confusion.I ment when it goes off road all it does is trailride and camp no rocks or serious mud.
  9. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    on four wheel parts web site it doesn't show that a lock right is made for a 14 sf only thing available is a detroit or auburn.
  10. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I plan on doing this to my 14bsf, the lockright number I found was 1950, fits '73 to 2000 w/9.5 " semi floating axle.
  11. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    thanks for the part #.How much and where did you find it?
  12. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Price went up a bit since i last checked, but Jegs still sells them
    Jegs Page
