locking brake...
Discussion in 'The Garage' started by s373n_rcr, Jan 13, 2004.
  1. s373n_rcr
    s373n_rcr Registered Member
    Jan 1, 2003
    63
    Ontario, Canada
    My 89' fullsize Jimmy has developed a severe braking problem since the cold weather and slippery roads hit a few days ago. When getting down to the last 10-15 feet of braking on slippery surfaces the right rear brake will lock up regardless of how slow I may be going. For about 4months that same right rear that locks-up also has had a 3" piece of it's leafspring missing, right on top of the overload spring. Could the broken spring be causing wear and binding that side up under a braking load? Axle taking a trek? Simple brake problem on that side? Also, when I pull away I can feel a load on the truck until I hear the same thud as it makes when it locks, then the loaded feeling disappears. Any ideas?
    Cheers,
    S373N /forums/images/graemlins/ears.gif /forums/images/graemlins/k5.gif
    89'GMC Jimmy,350TBI,SM465,33x12.50
  2. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I would pull the drum and check the axle seal. Sounds like it could be oil on the shoes.
  3. s373n_rcr
    Jan 1, 2003
    63
    Ontario, Canada
    Also, heavy grinding trying to get into reverse, 1rst and 2nd difficult to get into at times and sometimes truck doesn't jump but, creeps a little forward when I start it with clutch in (I park it in 1rst instead of E-braking it)...I'm going to try a clutch cable adjustment and draining and refilling with that good Lucas gear oil, see if that helps. The truck is making all the wrong noises and doing all the wrong things right now.
    Cheers... /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  4. dyeager535
    26,982
    191
    If thats a stock 465, don't expect to find much cable adjustment, it's hydraulic. Perhaps your hydraulic system is failing, thus not full disengaging from the engine when you depress the pedal.
  5. s373n_rcr
    Jan 1, 2003
    63
    Ontario, Canada
    thank you for pointing that out. oversight. used to the cables in my stable.
