locking differential - which one is it?
Discussion in 'The Garage' started by TheAustrian, Nov 15, 2006.
  1. TheAustrian
    TheAustrian 1/2 ton status
    Jun 20, 2006
    160
    Austria
    I found the genuine optional equipment list of my '79 Blazer. It has many optional equipment listet, among is a locking differential with code 1G80. I was told that GM offered two types of locking differential's. A limited slip differential and a 100% automatic locking differential (the M1009 CUCV where equipped with this 100% automatic locking diff.). Can anybody tell by the Code which locking type I have with my 12 Bolt rear diff?
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    not positive, but maybe you look up the rpo code for your year truck
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I would bet its the Eaton locking tyoe , commonly known as Gov Loc . I thought the limited slip was mostly for the earlier trucks . It wouldn't hurt to find out , as you should change the differential fluid anyway when you procure a used truck :thumb:
  4. TheAustrian
    Jun 20, 2006
    160
    Austria
    that was fast :eek1:
    "rpo code" - what's that?
  5. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    there all the little codes found in you glove box, all on like a 4x6 sticker...come to think of it, i`m not even sure if your year has them....i`m sure someone will chime in....
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    G80 is the rpo for a locking differential , but earlier 12 bolt rears were limited slip type and later ones were Eaton locking types . We have done this post before 3 times a year :thumb:
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The code is going to be G80 whether its one type or the other .
  9. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I'm voting for Gov-loc based on year and such, but it's worth a check.
  10. TheAustrian
    Jun 20, 2006
    160
    Austria
    yes, this list is the 4x6 sticker from the glove box.
  11. TheAustrian
    Jun 20, 2006
    160
    Austria
    Okay, since my K5 is a 79 I think it cannot be called as early 12 Bolt - correct? And if I open the gear cover, what will I see to identify which type is installed? I mean what will tell me it is a limited slip or a Eaton locker? Sorry if my question sounds dumb...
    And...does it make a difference when I change the pinion and ring? I think not...?
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The earlier type has big springs in the center , visible on both open spots of the carrier .
    The later one that actually locks solid at low speeds only , has a big giant block visible in the center spot of the carrier going to both sides between the gears , and the center pin goes through the center , and another part that you could move with your finger , and it would spring back .
    Ring and pinions don't care what differential carrier . The only requirement is the carrier has the right size for the gears , some are for higher ratios , and some lower ratios . The gears themselves don't really care for much as long as they get some oil and an easy break in :thumb:
  13. TheAustrian
    Jun 20, 2006
    160
    Austria
    @Paul383
    thank you for your explaination! I think I will be able to identify now. :bow:
