locking Differentials question?
Discussion in 'The Garage' started by 64suburban, Jun 17, 2006.
  1. 64suburban
    64suburban Registered Member
    Feb 9, 2006
    57
    tn
    I have a 75 K5 and it has optional locking differentials I was wondering if they were like limited slip or are they the kind that you can lock in, with some sort of switch. please forgive my ingnorance!
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    limited slip you have no control over what it decides to do which is usally not much
  3. 64suburban
    Feb 9, 2006
    57
    tn
    thanks, so is haveing them a good thing or do they do so little that it doesn't matter?
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,010
    7
    Binghamton NY
    IIRC Gm never put any type of locker/posi in fronts, other than certain military trucks. Anyways, what you have is probly an Eaton posi, as GM didn't put govlocks in them yet, not till the early 80s. It's a posi, so if both tires are on slick ground, they will both spin, but if one is on pavement and other on dirt, the one on dirt will most likely spin while the other does nothing.
  5. 64suburban
    Feb 9, 2006
    57
    tn
    allsome, it's good to know what your working with, thanks alot
