locking diffs in colorado
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dorucol, Jul 21, 2004.
  1. dorucol
    dorucol Registered Member
    Jan 12, 2004
    16
    I moved to Colorado recently, living in the mountains about 8800 ft elevation. Do I need lockers in one or both axles for winter? Also, I have a crate 350 in my Blazer, not much power at these altitudes. Do I need more cam, or lower gears. The ratios now are 3.73, with an od trans and 33 in tires. Thanks for any help.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I run a locker in the rear for snow. Works great! I leave the front diff open so it steers better.
    Try advancing your timing for a little more power. The rule of thumb is 1* advance over base timing for every 2000 ft of elevation over sea level. A good low end cam, intake, headers/exhaust will definatly help.
    Do you have TBI or Carb? It makes a difference in tuning/ jetting.
  3. dorucol
    Jan 12, 2004
    16
    Thanks for your reply, I have a non-electronic q-jet that I rejetted 2 sizes smaller, .072 down to .070., and advanced timing, runs better, but still weak.
