locking hubs on an older D44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Feb 12, 2002.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    I need help. I just converted to a D44 front and 14 bolt FF rear. I want locking hubs on the front but it is much shorter than the 1/2 ton 10 bolt. There is a cap on the end of the hub. It looks sort of like a 2wd front hub. There are 6 large bolts holding a plate to the end of it.
    Any Ideas? I believe it is from a 1974 truck. Just guessing based on the serial #'s
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  2. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    You have external hubs. Look at my pics and you can see what kind of locking hub you need.
    <a target="_blank" href=http://community.webshots.com/user/donimator>http://community.webshots.com/user/donimator</a>
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  3. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    Hey thanks man! I never saw that type of hub before. Do I need to buy a conversion kit with the hubs or should everything be included?
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    From your description..............
    It sounds like you have an older D44 3/4 ton HD external type hub.
    Suprerwinch makes hubs for them.
    You can get them from Blazer pics
    <font color=blue>Nevada... Where the pavement ends and the west begins
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That axle sounds like it's from a full time 4WD application. Installling the new locking hubs is pretty easy. But save those flanges that attach the axle to the wheel hub now. They're good to carry with you, just in case you explode a locking hub out in the boonies somewhere. You can just bolt one of the flanges back in place and be on your way. [​IMG]
  6. donimator
    Jun 11, 2001
    444
    Tacoma WA
    the hubs just bolt right on without any mods.
  7. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    How strong are externel hubs compared to the internal ones ?
    <font color=red>A BIG HAMMER CAN FIX ANYTHING.... </font color=red>[​IMG]
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    As long as the bolts stay tight you should have no problems.
    I have locking tabs on mine, I finaly blew a joint but the hub is good to go.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  9. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I've got the same thing you do. I use the flanges most of the time, but lately I've been running my Warns. Just kinda depends on what kinda mood I'm in and whether or not I want to mess with them. Watson at ORD got me the hubs. There aint nothing trick about em, just bolt em on and go.
    Like I said, and someone mentioned before, keep the flanges, they are good backups or unbreakable replacements.
    Kyle
    89K5
