locking hubs
Discussion in 'The Garage' started by jayccb1, Jan 4, 2005.
  1. jayccb1
    jayccb1 Registered Member
    Feb 3, 2004
    12
    wisconsin
    I have locking hubs and want to know if I can leave them locked for the winter and drive my blazer in 2wd and if I need to I can just shift into 4wd or do I need to lock them only if I am going to be in 4wd?
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    itll be fine to leave em locked, just be warned your mileage will suffer, as your axle innards and front driveshaft spinning. Also will make a little more noise.
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Yes, you can leave them locked all winter. Drawbacks are noted above.
    If it were my truck, I'd pull the hubs, clean them and repack the hubs and bearings before locking them up for the winter, but that's just me...
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can leave them locked, i do in the winter. with a 208 or 241 you can shift in 4wd while moving as long as the hubs are locked.
    id just unlock the hubs if you were going on a long trip or on the highway.
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    You stil have to have it in neutral right??
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Not to unlock the hubs you dont.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    no like if you have the hubs locked and you are driving you cant just reach down and put it in 4wd right?
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes you can, only into 4hi though. i do it all the time
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    wow cool, it doesnt grind or jolt or anything???
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nope. as long as the hubs are locked, the front driveshaft, chain and syncros are all spinning, just not enguaged. all it does is enguage the syncros.
  11. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    834
    Pinckney, MI
    4lo requires Nuetral. But I do it all the time from 2wd hi to 4wd hi. Dunes are fun in 2wd :):cool1:
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    cool thanks :D
  13. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Just let off the gas and pull the handle back. Prolly wont go in with your foot on it cause everything is under load.:)
  14. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Like shifting a dirtbike with no clutch..... harder on parts but it goes in.
    goin downhill just slip tranny in neutral then shift into 4by. No chance for problems........... took the tranny/case out more than enough times lol.
  15. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Don't even have to do that. I would blast down sand washes in 2WD and as soon as the rear end would start to slide out I'd reach down pull it into 4Hi and it would straighten right up. All in a matter of second and still under power.:cool1:
  16. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I got some Auto-Hubs Ill trade ya:grin: I hate these bastards I can tell the one is about junked out. It doesnt always wanna let loose. I was gonna switch to Warns but a Dana 44/14FF combo might be in teh works
  17. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    don't you have to keep it under 55 mph to switch from 2hi to 4hi
