Locking Plate???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Jan 16, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    DO I need the locking plate on my 85 tilt column installed in order to drive it????
    If not do I need to install anything in there in order to take up the space?
    1985 GMC JIMMY
  2. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    They are a bitch to put back together aren't they? Do yourself a favour and do it. If your steering wheel doesn't lock it will make it a lot easier to steal.
    Shawnboy.
    <font color=red>If you are having too much fun it's probably illegal.</font color=red>
  3. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    You can probably drive it that way if you put the same thickness washer in to take up the space, The washer will be just as hard to install as the lock-plate though. You can pick up a lock-plate tool fairly cheap. Check ebay and Lisle Tools, they are $40 form Snap-On so you should be able to find an OK one or a used one for $20.
    '70 K-20 San Diego, CA
    I know, I can't spell!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got the lock plate tool kit from Lisle. Picked it up a Pep Boys for short money. Makes it WAY easier to remove and install the lock plate. [​IMG]
  5. dyeager535
    26,975
    Go buy the tool for $10. You ocuold probably turn around and sell it on here for $5 later : ) Those things save SOO much time, and work on just about every GM car and truck from 73-90 something.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
