Locking washers on 14ff hubs, big question!
Discussion in 'The Garage' started by 8_YOUR_H2, Jul 12, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Ok, Im putting the hubs back on and I thrashed the weird lock washer on the 14FF you know the one with the tangs that go into the grooves on the lock nut. It looks like a spider or somthing. How do you install these with out bending the tangs? If you do bend the tangs can you still re use them? Any tips, personal experiences or anything would help me out a lot
    Brent
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Reuse them. They are still good pieces as long as they are not split, cracked or broken around the ring. /forums/images/icons/wink.gif
  3. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    You know whats weird is these lock washers are listed under the dana 60 parts book. The 14 FF book says all that holds the nut in place is a key?? WTF?? So somebody put D60 lockwashers on my 14FF?? I dont get it...I guess ill re use them and forget about it!
    Brent
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Brent, can you post some pics of these washers?
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Also, I cant remember what order they go in...I think, flat washer, adjusting nut, locking washer, locking nut...ughhh /forums/images/icons/confused.gif
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Here's a PM I got directly from "THE MAN"....Wes (ThatK30Guy) when I asked him the EXACT same question:
    Greg, the washers go in order starting first with:
    1. Flat washer with index key
    2. Lock nut, torque to 50 ft. lbs., back off 1/4 turn, retighten to 50 ft. lbs. all while turning the bearing hub to seat the bearing, then back off again 1/4 turn. Do not mess with this nut anymore.
    3. Spider washer
    4. Lock nut, torque to 50 ft. lbs. while turning bearing hub
    That's it. /forums/images/icons/smile.gif
    Worked for me....
  7. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Whew, you are a life saver! I took this thing apart a year ago and forgot what I was doing.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's one more step... The outer tangs on the spider should be bent down into the slots in the outer nut. It keeps the nut from backing off. /forums/images/icons/cool.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, what Harry said....bend the tangs over the outer nut. /forums/images/icons/wink.gif (this keeps the outer nut from backing off) Thanks Harry! /forums/images/icons/wink.gif
  10. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Did the same thing But fortunately I have an extra one still put together laying next to it. But now I don't have to pull it apart to see how too put it back together thanks.
