Lockout Hubs...
Discussion in 'The Garage' started by clubba68, Nov 27, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Why won't my lockout hubs from my 1/2 ton D44 swap over to my 3/4 ton 4x4? Figured it would save me some money, but just checked on Warn's application chart, and they are not interchangable.
    -Andrew /forums/images/graemlins/usaflag.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the hubs are different sizes i believe, i know when we put 1/2 ton hubs/rotors onto a 3/4 ton 10 bolt we used the half ton lockouts..
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lockouts are the same. Check the application guide again. Not only are they the same for D44/10 bolt in all internal hub configurations, they work on Ford, Chevy, Dodge, and any other brand that used internal hub D44s.
    Before you tell me I'm wrong, I've ran the same Warn Premium hubs that I bought in 2000 on three different front axles, in both 6 and 8 lug configurations.
  4. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I just saw another post on our board saying that they are the same so you should be good.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    They are all the same with the exception of the external and internal. Other than that, all internals are interchangeable, as are all externals.
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    YUP /forums/images/graemlins/thumb.gif
  7. clubba68
    Dec 6, 2002
    1,511
    Here are the lines off of the application chart:
    Model Year Spline Count Standard Manual Premium Manual Spindle Nut Kit Service Kit Standard Service Kit Premium
    1/2 Ton Pickup G ,H '69-87 19 9790 20990 32720 11967 20825
    3/4 Ton Pickup G '60-76 19 - 9072 - - 7302
    Kind of confusing to read, so here is the link.
    In the truck right now is the stock 1/2 ton D44 from 1970 and going in is a stock 3/4 ton D44 from an early 70's.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You probably need external design hubs.
  9. clubba68
    Dec 6, 2002
    1,511
    Now that just makes me angry. /forums/images/graemlins/smirk.gif
    -Andrew
  10. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    just a heads up...here's what one typeof external lock out looks like... [​IMG]
  11. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    thats the BIG hub D44 the one that are on the "1ton" D44's anyways theres another syle external and then also the standard internal that most people run... you can probably find a set of the internal hubs pretty resonably... and just use your old lockouts so that way you atleast are using the stuff that is more common, get prices at napa and mabe autozone I belive they carry the hub.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is no such thing as a 1 ton Dana 44. All 1 ton Chevy trucks had D60s.
  13. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Not before a certain year...somewhere in the late 70s I think is when they started putting D60's into 1 tons.
  14. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    77' was the first year for the D60 1 ton. Despite what some people think. There was a 1 ton rated 4wd before 77' but it had a D44 instead, and yes it isn't a "1 ton" front axle but the cargo weight and towing of the truck was rated as a 1 ton and that is what most people that don't wheel them care about.
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    but officially no 1 ton 4x4 or dana 60 front til 77 under GM trucks,
    anything before 77 was a K20- no K30 existed yet
    good luck with hubs swapping, i donthave a clue what ones will swap out, i know that in 77 there still was full tiem iron bolted flat hubs but soem 77 were the sheet metal chrome full time caps though.
