Lockright behavior when turning
Discussion in 'The Garage' started by rcamacho, Feb 9, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    :doah:
    I finished installing the 1955 model in my 14Bff last week. It locks up great under power. Around corners it will unlock around corners with some slight throttle pressure. However at low speed without throttle, it will stay locked and thrash a bit between the internal coupler lash range. From the manual it appears that this is normal behavior and just requires some adjustments in driving style.
    Confirm +/-?
  2. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    Mine will pop and carry on at low speed around corners so violently it'll make you think you broke something every now and then. Figured it was just a characteristic of a cheap locker. Still works good after a year or so, so I guess that's just the way it is. If it ever does go out, I'll buy a detroit next time... if it ever goes out being the most important part of that sentence.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks for the affirmation.
    I'll just power through turns and try not to mow down any pedestrians.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    peds on a trail or the rocks?
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Still a dual purpose rig. It still sees a decent amount of street usage.
  6. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    OK, I gotta ask, LockRite in the front or the rear?
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I am gonna go out on a limb here and assume that he doesn't have a 14Bff front axle . . . :wink1:
  8. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    :doah:
    Mine works fine around corners...If I get on it I get a chirp, but I cant hear or feal anything. Maybe Im just used to lockers. Ive had detroit's and lock-rights in a few different vehicles.
  9. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    off the gas and you have compression braking which, while not as much, is also transfering torque through the axle (from the tires forcing it to spin). yep, it will want to stay locked unless you lightly give it some pedal. Enjoy the new traction :D
    Micah
