Lockright in place of Gov-loc
Discussion in 'The Garage' started by dlaw36, Sep 7, 2004.
  1. dlaw36
    dlaw36 Registered Member
    Jan 11, 2003
    71
    Can you install a Lockright in the carrier of a gov-loc?
    I know the Lockright will fit in an open carrier.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope. I researched this last week by calling richmond gear myself.
    You're out of luck. Get a detroit or weld it.
  3. dlaw36
    Jan 11, 2003
    71
    I am not above welding it at all! Can you take the carrier out easily witout resetting gears and all that crap to do the welding?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Is this a 10 bolt?
    If so there is no reason to remove the carrier to weld it.
    Welding a 10 bolt up won't make it last long though, that's for sure.
  5. dlaw36
    Jan 11, 2003
    71
    10 bolt crap.
    My gov-lock is on the way out and looking for an easy fix until I find an upgrade.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Just weld the snot out of it. I welded up a 10 bolt a few weeks ago.
  7. dlaw36
    Jan 11, 2003
    71
    I am going to "weld the snot out of it" then! /forums/images/graemlins/rotfl.gif
    Which rod should I use?
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't know...probably 7018. I used my wire feed with flux core .030".
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The new no slip locker (lockright+) does have a version for the 10/12B gov-loc case (also the 14FF). Try asking for a no slip, not a lockright. Don't weld it, then you will need a new carrier when you realize welding a street driven 1/2 ton axle is a bad idea.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    No there isn't. The only application that is available for is the little 10 bolt found in the S10s. Our 8.5" 10 bolt, the 12 bolt truck, and the 14 bolt SF & FF are all out of luck when it comes to gov bombs and any kind of powertrax locker or no slip.
