Lockright noise?
Discussion in 'The Garage' started by southernspeed, Jun 23, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I did a search on this and read a few posts but have to admit I didn't read through 249 posts.
    I have a Lockright in my 12blt. Works fine but it is sooo noisey when turning!
    I have carpet and soundproofing and it is still LOUD. It's not so much a 'ratcheting' sound when you turn as a 'hitting the chassis with a hammer' sound! People turn and stare when I pull out of a junction!
    So, question is....am I alone? How does yours sound?
    Also, oddly, it seems worse (loader) making a right turn.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    It ain't the Frenchman ya ran over a forenight ago, makin' the banging sound is it? :laugh:
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    That's what they do:p:
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well , as long as the install is good , and the unit is good . And the 12 bolt is within tolerance , it shouldn't do it often . ( speaking of Powertrax Lockright , the real deal ) .
    Gotten so used to it driving , it hardly ever bangs at all .
    It does like to go bang when I do something important though , like repair something else and try to test drive it . Just got a straight ( first time in 4 years LOL ) tie rod from Marv . And on the way home it popped around a downhill right turn and thought my "new" tie-rod popped off :thumb:
  5. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    This is LockRite in the rear? Thats why there is also available the NoSlip. It does the same LSD action without so much of the blacksmithing noise. I have LockRite in the front and sometimes it sounds off like hearing a depth charge from inside a sub. I put the NoSlip in the rear and it made some minor noise for the first ~month, but after that you don't even notice except both wheels spin.:D
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What weight gear oil are you running? I have a lockright in my front 10 bolt that I bought used already installed in the axle. The PO said the lockright used to be loud in the front. Then he switched to a super heavy gear oil and he never heard anything from it again. I personally have never heard a peep out of it in 3 years.
    The gear oil used to quite this is Redline Heavy Shockproof gear oil. It isn't cheap but it works very well. I think Pauly is running that oil now too to try and help with the bangs.
    Harley
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Good tip, thanks.:thumb:
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    sounds like you need a spool my man!:haha:
  9. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    The Frenchman wouldn't make any banging after I'd run over him....but there is a strange onion smell!
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Well I wheeled with it today and all was well, it's just noisey on the street. It's a powertrax one and the axle's fine, running 85/90 oil. If it's ok like that then I can live with the noise as I love the extra traction!
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you can live with it is should be ok. When you change your gear oil next just use something heavier in the gear oil department to help dull the banging.
    An oil like Redline Shockproof or Amsoil Severe Gear with heavy pressure additives helps is a good choice or even just a standard 85w-140 dyno oil should help too.
    Harley
  12. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,029
    1,347
    Kzoo, Mi
    I have one in a rear 44, and it just clicks when going around a corner. Have you taken the cover off to inspect for anything loose, like the cross shaft?
  13. 4xcrazy
    Oct 31, 2003
    9,471
    5
    then he'd go from a clickin' and clankin', to screamin tires that go bald in 6 months,,,:crazy:
  14. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I have one in my 14BFF. It regularly chirps the tires and sometimes bangs. Getting it to lock/unlock is fairly predictable now.
  15. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I have one in the fornt of Patch, the wonder Yota. Usually makes noise when bound up. From your description of the noise it sounds about right. Sure would swear sumthin just broke up there, but you'll get used to it.
  16. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    The original cros shaft (12blt) was junk after 400 miles. I did check it for hardness before use but it didn't last long. I got one direct from Powertrax so hopefully this one will last.
    Went wheelin' this weekend plus 130 miles on the highway round trip and i'm getting pretty used to it and getting to learn how to drive tight turns better!
  17. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Now that I think about it, last change I put in Mobil1 75W-140 and they did get quiet. That with the favorable replies, it seems they do respond to the high vis synthetics.
  18. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    Yeah I have a lock right in my rear 10b and the best way to put it is bitter sweet...
    I run 85-140 gear oil and I never hear a peep as far as clicking around corners. But ever since I did my gear swap on my rear diff, I have had a lot of play in the diff. It is not the ring and pinion because I know they are set up corectly. I looked at the cross shaft and it was worn so I relpaced it with their recomended cross shaft and it didn't help. So I investaged more and the play is all from the locker so I will have to take it out and check it over for wear. The good thing is that is is still under warrenty so I will probably be calling Power Trax soon :rolleyes:
  19. berserker
    berserker 1/2 ton status
    Nov 19, 2005
    127
    columbus,ohio
    sounds like power trax is not that great
  20. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I think they're good for what they are. I'm getting used to it now, and it seems the noise is quite the norm. I think if you want a high end, super tough locker you'd have to go for a Detroit or similar but for an entry level locker the powertrax lockrite is good and very cheap.
