Lockright Spring Help
Discussion in 'The Garage' started by DERBINATOR, May 13, 2006.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    I was pulling apart a dana44 that has a lock right installed. I was pulling the carrier when I noticed a damaged spring coming from the opening between the 2 halves. It is not one of the 4 that hold the pins in place. This spring was very fine with maybe 1/16" dia. coil by 3 or 4 inches long. It was also tension only not compression. I don't remember seeing a spring like this when I installed it. What would it be doing? Am I gonig to damage something more if I run it?
    Derb
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Lockrights dont have springs like you have said. I put one in my 10 bolt (which is almost identical to the dana 44) and there was no spring aside from the 4 small ones. Sounds more like a gov-lock or limited slip to me....
    -Harrison
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    I maybe wrong, But I think it has 8 small springs 2 per pin.
  4. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    That was my thoughts that lockrights don't have springs like that. As I was just typing this I have had a revelation. The last time I ran this front end I broke an axle and the inner seal was destroyed hence the spring!!!! Sometimes I guess just talking about it stirs up your own answers.
    Thanks Again
    Derb
  5. 87BrnRsd
    Apr 21, 2003
    2,457
    Ahh yes, there are 8 springs. 4 really small ones that go into 4 other small ones. Anyways....good thing you figured out what the spring was. All I knew was that lockrights dont have large springs like that, and if they do, then mine doesnt have one....
    -Harrison
  6. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Good thing it didn't lubricate your R&P. :bow:
