lockrite for a 14bolt
Discussion in 'The Garage' started by shaun, Aug 23, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    How well would a lockrite hold up in a 14 bolt spinning 33 - 37's. I want a detroit but am going to wait to get that until I swap to 4.88's. Am I correct that you have to remove the carrier with a detroit and not a lockrite. Do you install a lockrite in the rear the same as you do in the front?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Full Floater or Semi Floater?
    The FF version, The detroit is a drop on. Simple and cheap.
  3. shaun
    Apr 22, 2003
    745
    Its a full float. What do you mean the detroit is a drop on ?
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  5. shaun
    Apr 22, 2003
    745
    I got it now. So detroit in the rear it is. Thanks guys.
  6. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    ya in a 14bolt the carrier is strong enough for a true detroit...whereas most axles the detroit replaces the carrier too....thats one big plus for a 14bolt easier and cheaper!! /forums/images/graemlins/thumb.gif
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Actually, all detroit lockers pretty much for axles that size and larger are drop in. They make no-spins for axles that are MUCH larger than the 14 bolt.
    The 14 bolt just happens to share the design of much heavier duty axles, so it is a drop in.
    The large Danas don't have this design, so we don't get so lucky for the front. But if ya ever needed a no spin for a semi or something, you'd likely get a drop in type.
  8. smprider112
    May 1, 2004
    624
    Beaverton,Oregon
    they make detroits for semis!?!?! I would never have imagined that
