Lokar pics
Discussion in 'The Garage' started by bear76, Feb 1, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Did they show up?
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    sweet. looks like a stock 4 speed with a twist. good job.
  3. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    Looks good.
  4. bear76
    Oct 16, 2005
    1,065
    here
    Right now it's just mocked-up, not completly mounted. It should raise up about an inch. I might need to modify the opening to fit some more.
    THANKS!
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Need a clutch pedal to complete the look :D
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    wow I thought you had a 465 under that shifter! :eek1:
    I was like why is the shifter so straight like that... lol :haha:
  7. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Dumb Question:
    Would a Lokar be able to handle off road vibration? Not pop out of gear?
    I'm looking at an Art Carr shifter as well.
    I'm also going with a Lokar floor mounted E-brake.
  8. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Im still a noob What is a Lokar?
  9. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    Brand name for a company that sell stuff for vintage vehicles. The floor shifter on this thread is from Lokar.
  10. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    Its a brand name of a setup that allows you to do away with your column shifter and linkage that goes with it. I got one to...
  11. bear76
    Oct 16, 2005
    1,065
    here
    I'm not worried about it poping out. It's mounted to the trans directly like in the above pic.
  12. jk5blazer
    Jan 28, 2005
    306
    Braselton, Ga
    I've been pretty tough on my blazer since I put mine in and have yet to have any probs with it poping in and out
  13. iwaxmyjimmy
    iwaxmyjimmy College web wheeler Premium Member
    Nov 3, 2006
    2,802
    34
    Greenville NC
    I want to go full manual reverse valve body and get a lokar 23inch shifter but I didnt find one at summit for the reverse pattern. Thats a killer looking shifter though.
  14. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I have the 23" nostalgia shifter. it would work with a reverse pattern. you would just have to push the button to up shift and it would ratchet down shift.
    never had a problem with vibrations or popping out of gear. I have had mine 7 years now and am hard on the truck, including rowing the shifter a lot when wheeling.
    the chrome is starting to pit, but I don't do the kind of upkeep that most hot-rod guys do.
  15. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Is the removeable tranny hump stock?
    Did you change out the column as well or just remove the shifter?
    How much $$ does it cost?
  16. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    Which shifter is that, the 16" one?
  17. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    OK thanks guys for the info. Where do I get myself one I hate me column shifter and always wanted a auto floor shifter. How hard is it to install?
  18. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    my 83 blazer has a stock removable hump. it makes tranny stuff real easy! i hear this is only in the blazers tho.
  19. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    Cool :D !
    If that's the case about no problems popping out, then maybe I'll get a Lokar instead of an Art Carr.
    I really like the 'stock look' of the Lokar:bow: !
    This is an excellent reference thread :waytogo: :bow: :bow: !
  20. bear76
    Oct 16, 2005
    1,065
    here
    My tranny hump is removeable, it even had the outline of the original shifter hole. So I cut along the outline for the stock look. I paid around 160 from summit and it's a 16" (maybe 18" I'll check later) shifter. Also, I changed out my colomn for a manual one.
