Long over due
Discussion in 'The Garage' started by 468k5, Mar 23, 2006.
  1. 468k5
    468k5 1/2 ton status
    Jul 28, 2004
    142
    SE Mn.
    You guys have inspired me! My 74 went into the shop today to start it's face lift.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    so what are the plans?:wink1:
  3. 468k5
    Jul 28, 2004
    142
    SE Mn.
    new tbi 454, cross over steering, 52" swap up front, 63" rear, rear disc, '83 cab and "shortened" short box and a few other odds and ends
    any other suggestions?
  4. 468k5
    Jul 28, 2004
    142
    SE Mn.
    update #1
    63" springs are in the rear! I could not believe how easy the old ones came out, I figured I would have to cut it all apart with the torch! But 32 years of Minnesota road grime, salt, mud and rust had no effect on them. Every bolts spun right out as if it were put together yesterday. The way it looks it gives me 7" of lift in the rear. was planning on less but I can live with it!
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    didnt think to clean everything off b4 did ya? haha me either. looks good man. so are you gona run a fuel cell since uve got 63's?
  6. 468k5
    Jul 28, 2004
    142
    SE Mn.
    couple questions though, will my shackle angle be ok once the body cage an gas tank are back on?
    And for the 52" front springs wich set would be better stock rears(top) or the other set, they look like they could be 2" lift rears but I'm not sure.
  7. 468k5
    Jul 28, 2004
    142
    SE Mn.
    I'll just knock the mud off as I go lol
    planning on reusing the stock tank
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    By the looks of it and the 7" lift in the back, i would go with the lifted springs.
  9. 468k5
    Jul 28, 2004
    142
    SE Mn.
    yeah I just thought of that after I posted it.
    My wife is right......I am a moron!:doah:
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    get rid of that cut up rear shackle mount asap. it will greatly limit flex. theres no way you can get the proper amount of shackle angle with it. either buy a flip or use the rear spring, front eye buckets. that mounts doesnt allow the same amount of sw3ing as a flip does. look in my sig or my gallery. i have pics in there of my old setup. i had an extremly steep angle. allowed for tons of drrop but the spring still flatened out. and for 63's i would run a long shackle and tons of angle. if you look at the other link in my sig is my new project. im gonna be running 63's out back. im mounting the flip rear spring, front eye hole 57.5" and am going to run a 7.25" shackle. should be a perfect combo:D
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    also you NEED traction bars with 63's cause of how bad the axle wrap will be
  12. 468k5
    Jul 28, 2004
    142
    SE Mn.
    yeah I knew the axle wrap was going to be an issue
  13. 468k5
    Jul 28, 2004
    142
    SE Mn.
    rear disc on front springs on
  14. 468k5
    Jul 28, 2004
    142
    SE Mn.
    one more
    still need to make new rear hangers
  15. 468k5
    Jul 28, 2004
    142
    SE Mn.
    fixed my hangers today and mounted the shocks still need longer shackles
  16. 468k5
    Jul 28, 2004
    142
    SE Mn.
    update time
    well I got to take it out this weekend.........I love it!!!!
    a few things I need to change though, longer shocks in the front, longer shock an shackles in the rear, and hydro assist.
    otherwise the 52", 63" swap works perfectly!
  17. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    So you found another Blazer body? I thought you were going with a pick-up cab and an ultra short 'box'?
    Rene
  18. 468k5
    Jul 28, 2004
    142
    SE Mn.
    it is a p/u cab and shortened box............welded together
    trying to keep with the K5 theme:wink1:
  19. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    Ahhhh, I see now. Good job!
    Rene
  20. 468k5
    Jul 28, 2004
    142
    SE Mn.
    ooooooooooooooooohhhhh I almost forgot the best part..........the name!
    seeing how it was a "mexican" low rider that is now muddin/wheelin truck...........
    Dirty Sanchez!
