long shackles
Discussion in 'The Garage' started by RedneckK5, Sep 9, 2002.
  1. RedneckK5
    RedneckK5 Registered Member
    Aug 15, 2002
    42
    texas
    i am thinking about building some longer front shackles to level out my blazer. anyone done this. any tips or pics.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    for the front or rear? if it's for the front just buy some hill 4 wheel drive extended langth shackles. for the rear, if you have a shackle flip it would work.
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Based on your wording I'll assume (yeah, I know) that you mean longer shackles for the front springs (since there are no "front shackles" for the rear, only front hangers). In that case, there is a limit on what you can lengthen them. Too much (like enough to appreciably change ride height) and you'll screw up your caster.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    oh sorry didn't see that. /forums/images/icons/crazy.gif
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    more caster isnt a bad thing
    the pinion pointing down may be though
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Good point on the pinion, I spaced that point, brain fizzled. But, as far as I know, while more caster may not be horrible, it's not and over all good thing since it can screw up the behavior while turning... But, then again, with our tires, I guess that nullifies most of the negatives of extra castor (within reason). Is that what your getting at (and I was missing)?
