long travel driveshaft ?s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazinzuk, Apr 8, 2005.
  1. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I am having some driveshaft problems I need a longer slip yoke. My slip yoke is 6" right now and I have been told going longer than this will make the driveshaft so heavy it will wear out the splines if I drive it on the street. I would like 8" of travel in the dshaft to I don't have to worry about seperating it again. I need opionons on long travel shafts for the street.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
  3. 1crzy88
    1crzy88 1/2 ton status
    Sep 7, 2004
    119
    NOR Cal
    I think he is reffering to the slip yoke in a 208 style T-case... right. :)
    T
    PS. i really don't know about your problem. I ran into the same thing...so i bought a np205... :laugh:
  4. divorced
    Jul 20, 2004
    5,115
    Maybe? He has a '73 listed in his profile which I would guess has a 205. I don't think 6" or 8" either one is achievable in a slip yoke rear of a 208 because the spline shaft just isn't long enough.
  5. dansblazer
    dansblazer Registered Member
    Sep 17, 2004
    32
    Oshawa, Ontario
    208 Slip Yoke
    Hello, just some feed back concerning a 208 slip yoke and high angle driveshaft...Go to the wreking yard and look for a 72 cadilac drive shaft. The slipe yoke is 8 inch long and there is a CV attached.......excellent for angle..Yes it slip in the 208 Tcase without any problems.....
    Have tried it and works excellent and also has not destroyed the splines....
    anyway just something that I have learned
    Regards Dan
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    From what I understand though the Caddy slipyokes are not splined all the way to the end of the slipyoke.
    Harley
  7. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    True. Jesse explains that on his site. Here's a Caddy shaft. You can see it's not splined all the way. Why bother?
    However, Blazinzuk still hasn't clarified front or rear?
  8. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    front driveshaft guys front driveshaft There is alot of stuff I could do to make my current driveshaft work like change the angle of the shackle put limiting straps on it etc but I want to know if anyone running a long travel driveshaft on the front on a semi DD is wearing out the splines on the slip yoke. I have talked to most of the custom places and get "you will be fine no matter how long the slip yoke is" to " 6" of splines is about all you can run anything longer gets too heavy and wears stuff out really fast" so how about it do you guys think an 8" slip yoke on the front driveshaft ( np 203 PART TIME and Dana 60 front axle about 10" of lift) would wear out really fast or what?
  9. DougK20
    Feb 18, 2003
    384
    Boise, ID
    Being part-time t/c you'll only be in four wheel drive when wheeling & bad road conditions. As long as you limit your high speed usage it's not going to "wear out" too fast. Get 'R Done......
