Long Travel Kit for 90's Blazer/Tahoe?
Discussion in '1992-Present Chevy & GMC models' started by k5james, Apr 10, 2004.
  1. k5james
    k5james 1/2 ton status
    Feb 25, 2004
    792
    San Diego, CA
    Long Travel Kit for 90\'s Blazer/Tahoe?
    Hey guys I've got a 72 K5 that I'm in the process of restoring but I'm considering picking up a cheap mid 90's Blazer/Tahoe for a daily driver. Is there a long travel 4x4 Suspension availabel for these rigs? Are there certain things I should look out for? Any info is much appreciated.
    James
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: Long Travel Kit for 90\'s Blazer/Tahoe?
    Long travel and GM IFS together in the same sentence is an oxymoron. /forums/images/graemlins/wink.gif The IFS front end just won't flex much at all, no matter what you do to it. The only way to get serious flex is to convert it to a solid front axle. /forums/images/graemlins/frown.gif
  3. k5james
    Feb 25, 2004
    792
    San Diego, CA
    From what I understand once somebody actually does some R&D the IFS will put out some serious travel. The problem is that it's easier/cheaper for lift company's to do the drop down bracket than to actually do some R&D and improve the IFS. Look at all of those desert racing 4wd Toyotas. Now that the full size prerunner market is starting to take off I expect some fab shops to come around and offer some kits. I've heard Kartek is working on one for the GM IFS but we'll see.
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The long travel kits that I've seen for the Toyotas use modified Porsche half shafts that cost in the neighborhood of $1,500 each! /forums/images/graemlins/yikes.gif And that doesn't include the price of the other components. Not exactly the hot ticket for the occasional off roader. /forums/images/graemlins/crazy.gif
  5. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    284
    158
    Gustine
    When I was checking out possible straight axle conversions for my 94 Sub, I came across a company that offered a kit for the later model Blazers. The company's name is Fabritech and I think they use a Cherokee front axle and a four link set-up that is a bolt-in. It looked pretty cool. /forums/images/graemlins/waytogo.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the toyota long travel kit i looked at you could use t100 shafts as well as the porsche shafts..
  7. k5james
    Feb 25, 2004
    792
    San Diego, CA
    A majority of Toyota long travel kits use the t100 shafts due to cost. I might have to check out that fabritech kit. Like I said hopefully the aftermarket will start to see that we don't just want a lift, we want some wheel travel also.
  8. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    Yea you want what i want for my ifs rig it needs more travel as you can see here i have it flexing ok. im trying to come up with ways to improve the flex. i already have taken out sway bar and have tbars minor tightened up to allow more travel but still not rub anything under full flex.
