longer brakelines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigjblazer, Apr 30, 2002.
  1. bigjblazer
    bigjblazer Registered Member
    Apr 9, 2002
    89
    Atlanta, GA
    Is there anywhere that sells longer brake lines, that ARENT stainless steel. Those are too expensive now, and id be happy with just some longer rubber ones.
    BTW I have an 84' K5 with 4 inch lift and 35's.
  2. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    Long rubber ones aren't the best idea as the rubber will swell absorbing the energy meant for your brakes; especially on with longer lines - this might be why I haven't seen anyone selling them.
    Try relocating the line to come out under your frame.
    Or you could splice in a new metal line to a bracket below the frame.
  3. FireBlazer
    FireBlazer Registered Member
    Apr 27, 2002
    10
    Milpitas, CA
    I once heard someone say to use 3/4 ton suburban brake lines, there a little longer. It was instead of moving the lined under the frame. I don't know if it was fact or not.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i have my factory rubber ones that i used on my 6" lift...they seemed a lot longer than any of my buddies brake lines...measure yours from end to end and ill measure mine and maybe you can take em off my hands...
    Later
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    lines from an 86 chevy van should do for you, i put these on my truck till i can go stainless,
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I had all three of mine custom made locally. IIRC, I got +12 on the fronts and +15 on the rear. They are reinforced rubber lines (rated for something like 5 times max brake pressure, they will not swell) and they are even DOT approved. All three custom made totalled less than $100. I'm not home to check but seems like they were actually around $80 or so including the protective spiral wrap (springs around the rubber hose). Might search, seems like I posted the complete info about 2-3 months ago when I got them...
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    yeah what ever happened to them being like 30 bucks for 4 inch longer ones?
    i should have bought a bunch of sets then.
    grant
