Longer Break lines
Discussion in 'The Garage' started by **DONOTDELETE**, Oct 8, 2002.
    I am putting a 6" lift on my K5. can someone tell me what length I should get. I am getting the steel break hoses. I have a 14bff rear and a stock front end. Thank you for your help.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    so you will be running a 8 lug rear and a 6 lug front? /forums/images/graemlins/confused.gif
    every reputible manufacturer has 6" lift lines, call your fave parts people
  2. I will be doing eather a 6 lug to 8 lug convertion or swaping the 1/2 ton 6lug to a 3/4 ton 8 lug front. What length do you suggest Zakk.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    well, if you are going for a long travel suspension for a all around rig like most of us, i would say the 13" lift ones /forums/images/graemlins/eek.gif
    I would rather have too much brakeline than not enuff and "accordian" the things out /forums/images/graemlins/rotfl.gif
    i think Skyjacker has 13" lift length ones. braided steel, so they are more resistant to scuffing, etc.
  4. cool thank you Zakk I will do that. Another quesition is with out a ramp or anything how can i judge my wheel travel? I mostly have sand dunes by me.
    Thank you for your time with this.
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    well, i am not really sure, you could judge it by your spring rates, shock length, etc.
    MANY factors come into play when really getting into RTI scores and flex performance.
    #1 question to the need of the very long rear brake lines is do you plan to do some sort of shackle flip?
  6. I am putting 6" spring with out blocks in the front and 2" springs with ORD's shackle flip on the rear. I will be rumming 35" x 14.50" x 15" boggers.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    this is totally seperate, but if you are running dunes alot, a shackle flip might not be or you. The shackle flips and soft springs lend themselves to axlewrap, which is not a good thing for sand & Mud people.
    If you get it in tellico and other rough spots, maybe tame it down a bit in the dunes, as i do, for superior overall performance.
    and remeber: NEVER PUT BLOCKS IN THE FRONT! very dangerous and steer clear of people that have them on their rigs
  8. No I go easy on the mud and dunes. I need to get the front diff fixed before I can go rock crawling. Thats why I am going to the flip.
    Oh i dont run with any one with block in the front. I have seen them on Base and I just laught at them.
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    here is my uber-suspension vision:
    6" soft front springs
    6" Shakle flip/spring combo (pick fabricator of your choice)
    X-over steering
    Longer shocks (F-150 towers in front, inboard rear)
    super-long brake lines
    Rear Detroit Locker in your 14BFF
    ARB locker in your D60 front
    With that combo, you can dablle in about anything, IMHO /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
