Longer Driveshafts?
Discussion in 'The Garage' started by Jeremy_C, Sep 3, 2002.
  1. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    I need a driveshaft around 51 inches long, does anybody have one or know where i can get one?? Your help is really appreciated. /forums/images/icons/laugh.gif
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    can you give any more detail as to the style?
  3. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    I'm not really sure what you mean by style, but its for a 1978 chevrolet pickup. t400 transmission, with a four inch lift. Obviously its a rear drive shaft. Is that the info you were needing?
  4. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    ya can just go to a local driveshaft shop. they can make it i'm sure. that would be all i can think of unless ya want to spend some $$ and go for a badarse driveshaft from jess at high angle driveline . hope this helps. later
    jacob
  5. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    was referring more or less to a fixed or slip style shaft, but if it's in a 78, it should be fixed, i think.
  6. Jeremy_C
    Mar 26, 2002
    1,381
    East TN
    We dont have any local drive shaft shops around here. Whats the difference between fixed and slip??
  7. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Driveline shops are pretty much everywhere. Here's a few listings I found quickly on the internet. Not sure where exactly you are located but maybe one of these is close enough. Other than that, best bet would be to have one made and shipped to you.
    Chattanooga Driveline Service
    PO Box 71569
    Chattanooga, TN 37407
    423-624-4194
    Sonnys Driveline Shop
    6606 Rutledge Pike
    Knoxville, TN 37924
    865-544-0144
    Ferguson Driveshafts
    2040 Fernwood Church Road
    Morristown, TN 37813
    423-586-1597
    Spicer Driveshaft Assembly Inc
    187 Spicer Drive
    Gordonsville, TN 38563
    615-683-8201
    Bowman Driveshaft Repair
    4127 Timberlake Road
    Johnson City, TN 37601
    423-282-8009
    Halls Garage & Driveshaft Repair
    1263 Louisville Highway
    Goodlettsville, TN 37072
    615-859-0223
    Slip yokes slide into the t-case and the shaft is solid, fixed style are bolted to the t-case output shaft and have a slip shaft.
  8. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
