longer rear shackels
Discussion in 'The Garage' started by 86chevybanshee, Aug 15, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    whats everyones opinion on a lowering shackle used for a lift shackle with a shackle flip? im looking to gain another 2 inches, so i can take my block out, but i dont want to buy new springs
  2. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    They work but it will affect 3 things. If you don't compensate for them, you will have problems.
    1) shackle angle
    2) pinion angle
    3) driveshaft length (most cases but not necessarily yours)
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think another problem that may occur is if you tow anything, the rear will have less stability with a longer shackle in the rear AND the flip.
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Too thin. The stock shackles crush when used hard. The lowering shackles crush, collapse, tear, and worse when actually wheeled with. I would go XJ (jeep cherokee) rear lift shakles first.
  5. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Here is a pic of mine and I have had 0 problems.
  6. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    what knd of shackle is that?
  7. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I got them from Echobit when they were around...
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I like that flip. Is that your design or bought?
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    He got them from Echobit when they were around...
