longer rear shackle question
Discussion in 'The Garage' started by BL1TZKRIEG, May 18, 2006.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    I have a ord shackle flip with stock shackles
    I was wanting to get some longer shackles like the ones kurt makes
    heres my problem I have a cv shaft and the pinion is pointed about 5* down
    I can feel a small vib once in a while
    I was wondering how many degrees the 5" or 6" shackles tilt the pinion up?
    I would to get a better angle with out having to install shims
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    the shackles like the ones kurt makes won't work for you. His are the plate style shackles like your front shackles. They work for his Flip'N'Switch, the switch portion of which refers to switching to that style of shackle. ORD sells a 6" HD shackle that is the same design as the stock one, just stronger and 6" long.
  3. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    crap I meant these ones sorry
    :D
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    haha forgot he was making these now
  5. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Before i did the flip and switch with a 6" shackle, i had a 4" block and an add-a-leaf. My pinion war closer to flat with the ground than lined with the driveshaft. I now installed the flip and switch, 6" shackle, and a zero rate to equal out to 6" of lift and my pinion is just about pointing straight at the tcase, the diff is just slightly downwards. I have no vibes that i have found and i drive mine daily.
  6. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    I'm wondering if I should go with 5" or 6" shackle :thinking:
  7. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Kurt has so many new products coming out all the time, it is hard to keep up with them.
  8. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    1 thing you may want to think about is that going from the stock shackle to a 6" is going to give you an inch of lift, give or take a lil.
  9. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    1/2 to an 1" of lift should be fine
    right now I have 4" tuff countys in the front and 1"zero rates in the back and it still looks a little low in the back
  10. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    how much lift do you have for the front?
    what type of springs do you have?
  11. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    I have 6" lift springs. I dont know the company that made them. They are stiff but still move when needed.
  12. BL1TZKRIEG
    Jan 4, 2005
    196
    OREGON
    nice rig :waytogo:
