Longer rubber brake line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mastiff, Apr 13, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Does anyone have the exact part number (or vehicle model/year) for longer factory style front brake lines (I think people mentioned NAPA)? This is for a K5 with 4" lift. I foolishly used the drop brake line bracket when I put on the lift, but now I want to do it right.
    By the way, do the longer rubber lines still have the rigid metal tubing on the brake side to keep the line out of the tire, or are they like the braided ones that need to be tied to the shock or something?
  2. mxrcr589
    mxrcr589 1/2 ton status
    Apr 17, 2003
    148
    poop
    i asked the same question a week ago and this is what someone told me, the front part numbers worked, but the napa part number for the rear didnt work for me, i dont think its the right part number-
    Front brake hose:
    These ones are for the left front of a 1994 2wd 1 ton and are around 25" long. $13.99 at Advance Auto. Napa wants $16.69.
    Tru-Torque (Advance Auto): H38873
    Napa: H38873
    Bendix: 78227
    Raybestos: BH38873
    Wagner: F124600
    Rear brake hose:
    Napa #4138068. It is $13.99
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks. It's weird you say the left side. Is the right side of a 1994 2wd 1-ton a different length? Should I really get two lefts and put one on my right side?
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I bought a right and left for an 88 C1500.
  5. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Hmmm. I went to four auto parts stores today and nobody carries these hoses. Must be for a fairly uncommon vehicle.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, you NEVER see 1/2 ton 2wd 88-98 Chevy trucks on the road. /forums/images/graemlins/rolleyes.gif
  7. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I was talking about the list of equivalent part numbers above that. It was not stated what vehicle it is for. Either way, nobody had it, and nobody could even order it. Sheesh.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    These are the part #'s I used, the front brake hose is 25-7/8" long:
    Part #'s:
    Napa - 38872
    Raybestos - 38872
    Auto Specialty - HB-86045
    Coni-Seal - BH-177767
    Carquest - SP8820
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I personally would go with braided steel break lines instead of rubber.
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The stock rubber ones lasted 30+ years, why change a good thing.
  11. vegas76k5
    vegas76k5 Registered Member
    Apr 20, 2003
    31
    Las Vegas, NV
    Part #'s:
    Napa - 38872
    Raybestos - 38872
    Carquest - SP8820
    Will the above fit a '76 D44 with out any modifications? I have seen a few threads on this subject and I am lost. /forums/images/graemlins/confused.gif
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I have a D44 on mine and I only had to do 2 very slight mod's. I had to shorten the banjo bolts about an 1/8" and ream the hole out for the banjo bolt out to 7/16", other than that it works great /forums/images/graemlins/thumb.gif
  13. vegas76k5
    Apr 20, 2003
    31
    Las Vegas, NV
    Thanks for clearing that up for me. I'm going to try and pick some up during lunch today. If I'm lucky, I'll get them on tomorrow so my weekend will be free to play.
    Mike
  14. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    Or use the calipers for a ten bolt. same junk , wont have to modify the brakelines then. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  15. vegas76k5
    Apr 20, 2003
    31
    Las Vegas, NV
    Any one try this? Sounds easier than messing with the banjo bolt and reaming the lines. The 10 bolt calipers bolt right up to the D44?
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes they do. They're cheap as well.
