Longer Shackle = Better Articulation - Ja oder Nein
Discussion in 'The Garage' started by BigBurban350, Jun 27, 2003.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Will a longer shackle in the front or rear give you better articulation on the axle you put the longer shackles?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    on the front it could if your springs are hitting the frame wen you flex up. so longer shackles on the front could allow some additional flex.
    on the rear im not sure, borrego could probably answer that for ya.
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    It wont give you better articulation. It will just give you additional lift and make you have to correct the pinion angle more is all.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The potential is there even without avoiding interference.
    Long shackles allow the spring eyes to move in a flatter (larger radius) path. In droop, they can move further before experiencing increase in "rate" due to alignment of the spring arch with the mount; after which point further movement is possible only if you distort the spring arch into a "V". In stuff, you don't experience the leverage induced rate fall off as quickly, leading to a more consistent rate. This all assumes an arched spring with shackles in compression and starting from a more-or-less vertical shackle orientation...
    They also cause more tortional force on the frame due to leverage, and the shackle itself must be considerably stronger for the same reason. Also, the increased leverage produces reduced frictional effects, and more deflection effects in the bushings (may lead to damage). And, don’t forget the affect on pinion angle, jacking/squatting effects (depending on angle), wrap effects, differences based on arch and progressive rate, etc. It’s a balancing act and there are many things to consider.
