Longer Slip Yoke instead of new Dshaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, May 20, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    Is it possible to go to a drive shaft shop and get a longer slip yoke instead of getting a longer driveshaft or a whole new one or is that what the shop does when you get a longer drive shaft?
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    To save some money you could go to the junkyard and dig for a driveshaft that would fit.Just take good measurements of what you need.I used a shaft off of a shortbox chevy that had a auto and 203.My ride has a 4 speed and 205 and 4" lift.I got mine free from a friends parts truck.Or you could also have your shaft lengthened buy a drivetrain shop or machine shop.This is usually cheaper than a new shaft.Brady
  3. Brady
    May 6, 2000
    628
    Parachute,Co
    Oh yeah.I just shortened a driveshaft myself today.It is for the frontend.I got tired of breaking the CV joint and spending $75 to fix it.I took an old shaft I had that has just one u-joint on each end.I ground off the weld on one end to remove the yolk then I shortened the tube to the right length and welded it back together.If you do this take carefull measurements of what you need.since mine is for the front I probally won't have it balanced.All I do is rock crawl.(slow)Also make sure they are the right size u-joints.Not sure how I'm going to attach the shaft to the t-case yet though.The front u-bolt is a little small for the t-case yolk.Need to goto the parts house and see what they have to use.Brady
  4. Impex
    469
    Chandler, AZ
    How does a drive shaft shop lengthen a D-shaft and how much does it run $100-200?
  5. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    they replace the tube! About 50.00 to 80.00
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Well this is not going to be to informitive because I gave the mag away(Petersons 4Wheel&Offroad),but...someone is making a longer slip yoke. If you need more travel, not just the legenth, and have a newer style x-fer case this would be the way to go. If you have a fixed yoke you can get as long a slip shaft as you want. Most driveshaft shops just do a retube when you need more shaft. In the Atlanta area it will run $75-$150. If you have more ? repost and I'll get the issue back,Jim.
    BigJBear '80 GMC
  7. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    I just had my driveshaft lengthened last week. I broke the yoke on the driveshaft....the one that connects to the slip yoke. When I put the 6" lift on my Jimmy, I noticed the slip yoke had come out quite a bit. I was planning on getting it lengthened, but it broke before I had the chance. I just got it fixed sooner than I was expecting. It cost me about $120 to have it lengthened, balanced, and a new yoke put on......I am very pleased with the company that did the work. "Crazy Train" drives a lot better, there isn't anymore vibration. Good luck.
    Alex
    Wichita, KS
    What me get stuck? NEVER!!(Famous last words)
