Longer water pump?
Discussion in 'The Garage' started by jerry303, May 28, 2004.
  1. jerry303
    jerry303 Registered Member
    Apr 28, 2003
    79
    Littleton, Colorado
    I am finally getting around to putting my first gen back together and I got to the water pump, got the first one all mounted up and the bracket which mounts to the alt and water pump has a large space now...i might be able to use it but i would have to use some type of spacer which seems like a bad idea. i then called up the parts store and they told me they had "another one" and i took the first one back and got the other one, and though it looks much more like the pump that i took out the space still exists. The first one I got was part number c1301270 and the second one c1301250. i can provide any pics if it would be helpful...thanks, jerry
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    is it the stock engine because later small blocks use a different water pump
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I know exactly what you're talking about. some pumps are made with the correct offset for your bracket and others are made differently and need a spacer that is about 3/4" long or so between the pump and bracket. The pump usually comes with the new spacer.
  4. jerry303
    Apr 28, 2003
    79
    Littleton, Colorado
    The engine itself is a goodwrench, but the bracket was from I believe a 76 3/4 ton.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    1st gens came with short water pumps. So you are using a crate engine with long water pump and 76 brackets?
  6. jerry303
    Apr 28, 2003
    79
    Littleton, Colorado
    Yes, as far as I know. I did not do the first engine swap, so I cannot be sure what truck that the engine and other drivetrain parts came out of, it was 3/4 ton and he said 76 but he might be wrong.
  7. jerry303
    Apr 28, 2003
    79
    Littleton, Colorado
    What year should I get the water pump from?
  8. jerry303
    Apr 28, 2003
    79
    Littleton, Colorado
    Help me get this thing one step closer to being on the road! and off the road too
