look at my drive shaft and tell me if I am stupid
Discussion in 'The Garage' started by az ranger, Mar 1, 2007.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    long story short 1 month ago I dropped my driveshafts to rebuild my 208. a month goes by I finally finish my TC and start bolting things up. I get to my rear driveshaft and it is now about 1 inch too short and wont bolt to the flange.
    this driveshaft is a tom woods shaft that the PO installed. I have had my jimmy for about 3 years now and I swear the last time I had the rear shaft out that it would lengthen or shorten on splines by a couple of inches. Now I can not budge it either direction.
    1. Does this look like a shaft that has the ability to travel longer or shorter
    2. why would it just go shorter when I pulled the transfercase out but now I cant lengthen it.
    3. Am I missing something else, I thought maybe I mixed up the front and rear flanges on the TC but they are the exact same size so It should not matter.
    I have done everything short of hooking a come-a-long to one end and that is next
  2. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Looks to me like it would extend.Maybe it's just the seal in the splined area try taking the grease fitting out,and then extending it.
  3. wildmandave
    wildmandave 1/2 ton status
    Jul 15, 2006
    127
    salina kansas
    should extend about 4 inc. just have to pull on it......:haha:
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Now that a sig line.:D
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Pump some grease into the fittin', it should pop 'er open.
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    X2!!
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Just give a tap on the yoke in the forward direction and it should move. If not then try the grease trick like someone already said. If that doesn't work then plan on spending some money on it.
    Also if that's your rear shaft then someone installed a SYE kit on your NP208.
  8. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    your stupid.... err sorry couldn't resist, you asked for it though :D
    anyways yeah pump some greae into it and she'll break loose and pop out :wink1:
