Look Decent?
Discussion in 'The Lounge' started by mikey_d05, Nov 1, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I have an assignment due for a technical communications class tomorrow, does this diagram look pretty decent? It's a rough rendition of a recentered Hummer rim, I know the drawing isn't all correct but it doesn't need to be.
  2. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    Yep, looks real good. What are you studying?
    Might want to change 'lightening hole' to 'weight reduction hole'.
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Goofball!
    He's studying exploded drawings of Hummer wheels!
  4. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Studying to be a mechanical engineer. Good suggestion, couldn't think of sophisticated names for the majority of the pieces.
    Have to do a 5-6 page "technical description" with a diagram. Couldn't find a worthy diagram, so I just drew up my own in solidworks.
  5. justhorsinaround
    Sep 16, 2003
    6,798
    Dunno if it's to detailed or not but shouldn't you have nuts in the diagram for the clamping part?
  6. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Yeah, I was gonna say that you meant "lightning" ... then realized :doah: I was wrong... but "weight reduction" just SOUNDS higher tech.
    There were these laptops years back we used to work on ... had two battery slots, but only came with one battery. The other slot had a "weight reduction module" in it, an empty plastic case :rolleyes:
    Oddly, the case had a door in it, so you could keep your stash inside ... unofficially they were called the "pot smuggling modules" :screwy:
    I digress.
    -- A
  7. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    O-ring and groove:laugh:
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Are you supposed to be harvesting corn? Ya know they started putting lights on tractors after 1940.
    Yeah, I remembered that when I drew it but like I told Kert, my prof. is like 80 and could be a nun, she isn't gonna know what the hell I'm talking about even if I broke it down to "the rim is made of steel, the tire is made of rubber" level.
    Oh, by the way, I grabbed the dirty orbital from Kert, so the clean one is all yours.
  9. Stomper
    May 11, 2002
    3,767
    Iowa
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Oh, did I forget to say that the dirty one had all 4 adapter fittings and less endplay in the input shaft. :D
    Sorry, at the rate it's going my buggy will be done before your truck anyways. Try to keep up. :p:
  11. Stomper
    May 11, 2002
    3,767
    Iowa
    Don't doubt that for a minute[​IMG]
  12. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    You suck Brett I started in on long hours the same time you did but ive got another 3 weeks minimum...ugh this sucks
    oh and mikey that looks good, im glad im not the only one that used offroading in every available facet I could when I was in college.
    By the way you do...what did the VANDALs do to my truck? IE...what did you guys do...
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Kert's gotta get his camera runnin'. :D
  14. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    ...wheres my beer i need to drink to forget that I read that
