LOOK!! Factory GM TBI intake manifold cracks? LAYNE??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thebigdaddyof2, Jul 1, 2003.
  1. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Anybody know for a fact that the Factory GM TBI intake manifolds have a tendency to crack and allow coolant to enter the cylinder(s)??
    I have been told by some that this can and has happened.
    These were not instances of overheating though.
    Anyone else experience this?
    Anyone have any pics of a cracked TBI intake manifold?
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Re: Factory GM TBI intake manifold cracks??
    I have heard that but I think its mainly in the 93 up era, they have a little different intake (has a groove in the thermostat housing... thats not the problem but those manifolds found after 88 or 93).
    It does happen, haven't heard or had it happen to my 87's.
    No pics sorry.
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Layne had it happen. Thats why he didnt make the Y2K5 run.
  4. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Right, I know it happened to Layne and I'm pretty sure Scott from KC was saying it had happened to him as well. I just wanted some other opinions/testimonials before I rip the intake off of my '87 Burb. I'm losing coolant somewhere and I can't find a leak- anywhere. The other (strange) clue is that I will randomly get a white smoke....but this seems to come and go. Not a drop of coolant in the oil. This is not like any cracked head or blown head gasket I've seen before. I'm wondering if, in fact, my intake is cracked and dropping coolant into the cylinder(s) randomly. I'd hate to pull the intake for nothing tho...
    Anybody else see this on a TBI setup??
    Layne, if you read this, do you still have your old TBI intake?? Where did it crack??
    Thanks for the info everyone.
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    If I remember right the ones I heard about cracking where in the back, passengers side? Not in the front /forums/images/graemlins/thinking.gif
  6. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    i have a 87 tbi 454
    my intake cracked in the (i beleave it's called the plenium)
    right below the tbi there was a hair line crack between the two sides of the intake.
    my machinest said he see's that all the time.
    i also was losing coolent but it turned out i had a bad head gasket and it was sending the coolent out the exhaust.
    don't know if this help's.
    dave
  7. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Thanks guys.
    Anyone else see this??
  8. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I have an 88 and I am slightly loosing coolant also. No leaks or drips that I can see. I also replaced the intake gaskets not too long ago also. There is no noticeable difference in temp cooling, but it leaks down enough just to be annoying.
  9. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: LOOK!! Factory GM TBI intake manifold cracks??
    weird. I had looked over this topic for awhile but after reading everything else on this site I desided to read this one too. and I get to add to it.
    My dad has a 90 burb and his has a slow leak of antifreeze too, now I know where it's going,LOL
  10. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    Well I'll add my 91 to the list of slow leakers.
  11. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    At the shop i work at we had a truck come in for a warranty head gasket that turned out to be a cracked intake. BTW the truck was a 90 C1500. The intake was cracked and allowing coolant to make its way into the #7 cylinder.
  12. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Interesting, thanks Jason.
    Are you guys seeing intermittent white smoke?
    I put about 400 miles on my Burb over the weekend. I saw no pattern to the white smoke. Sometimes at startup and sometimes not. Sometimes when it was hot and sometimes cold. Makes no sense to me. I used maybe a 1/2 gal of coolant.
    Layne...?
  13. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    My manifold cracked between the thermostat housing boss and the number 1 intake runner. I happened during the trek to Colorado. It happened rather quickly though. It managed to drain the radiator before I could shut the truck off. Had to replace the motor.
  14. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    cracked water passage in the head maybe? causin coolant to leak into the cylinder? Just a guess.
