Look here!!! Can you help?
Discussion in 'Pacific Region' started by tRustyK5, Sep 23, 2002.
  1. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    OK, just got a call from Gandolf. He did a tune up on his truck yesterday and now his truck has quit on him after a bit of backfiring and odd starting probs. Bear with me on his location...I will find out more exactly but as far as I know he had just exited the Caldecutt tunnel heading to Walnut Creek from Oakland. When he got to the grade it began to backfire and stuff and I believe he took the next exit. He made it through the first intersection when it quit on him. Is there anyone nearby than can help him out?
    Rene...will provide Mark's cell by pm
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Nobody?? /forums/images/icons/shocked.gif
    Rene
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i am DAY'S away...is he in a safe spot?
  4. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    MOST of us are working right now.
    Try PM'in SAVAGE1 He's in Alameda next to O-town...
  5. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I figured most were working...he is blocking a lane on an overpass. He was heading fromwalnut creek towards Hayward (??) got through the tunnel and took the first exit to Highway 13...got around the exit and on the next slight rise going over the highway it quit.
    This is an 89 Blazer with TBI...any thoughts? He has confirmed the cap and rotor are not damaged, the firing order is correct and all leads are on tight. I'm thinking a bad injector or something along those lines. The backfire could have been a lean misfire...
    Thoughts anyone? SAVAGE1 is not online to my knowledge. I'll send a pm anyways...
    Rene
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    try PMing Dan (gokartergo) he has the master list with contact info for SAVAGE1 and everyone else for that matter.
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Savage1 is in alameda and Liftedassdodge is in Alamo.. 1979jimmy should be near by also...Dan
  8. onebourbon
    onebourbon Registered Member
    Apr 24, 2002
    18
    Alameda, CA
    (SAVAGE1 posting)...
    Damn!! I just got this message and its 8:00pm. I called Gandolf anyway to see if he was still around. He ended up getting towed back to Walnut Creek... $120. I feel really bad cuz at the time he broke down I was at work, and I was only 10 mins away!! To make matters worse he was stranded on an overpass in the slow lane, no shoulder, and it was hot as hell. /forums/images/icons/confused.gif Sorry I couldn't be there for you man. Good luck with the prob.
    Rod
  9. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    double check the cap-n-rotor. i had an intermittant problem with mine. traced the problem all the way to the freakin fuel pump before i put on another cap-n-rotor, and that fixed it.
    i've got an 89 also, so if he needs a comparison vehicle to check anything, i'm here.
  10. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    It sounds like this wasn't a roadside fix anyways. I was hoping it may be a simple problem easily fixed...
    Thanks to all that responded!/forums/images/icons/cool.gif
    Rene
