Look what I made - traction bar mounts
Discussion in 'The Garage' started by bigburban383, Dec 30, 2003.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Nice need pics of them mounted... /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    As soon as I get my truck done you see it all /forums/images/graemlins/thumb.gif
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    thats pretty cool looking, where do the red boxs mount?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Looks like below the frame to hold the rod ends.
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Inside or outside? Inside the frame would be open, outside depending on backspacing and shock location there might some interferences. Are burb frames thats much different from blazer frames I'm not picturing it right? /forums/images/graemlins/thinking.gif
    Also where can you get those tabs to weld onto the axle? Seen them on eBay but the guy wanted $2-3 each /forums/images/graemlins/blush.gif
  7. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
  8. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    The red box mounts are welded directly to the frame. The angle iron follows the contour of the frame (so boxes are inward). The axles mounts are then welded between the diff and shockmounts. I made them closer to help when I articulate its closer to the cent of rotation. I made those orange axle mounts, bandsaw, drill press and sander. Its just rectangle plates 1/4" x 4 1/2" x 3"
  9. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    But wont they bind when the suspension compresses?? The axle moves in an arc from the shackle compressing and this will arc in a different direction as its mounted at the front of the axle. Or am i just an Idiot /forums/images/graemlins/thinking.gif
  10. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    The axle doesnt move with the shackle movement. Though theres an arc from the pivot point of the front spring mount. The axle will just twist a little to compensate for the trac bars when it compresses or depresses...In theory in MY head...if somebody knows something that might help me please tell me.
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    On leaf spring cars that are set up for drag racing, most use something similar to this to alleviate the suspension bind.
    Here is what Competition Engineering has to say about it:
    "The use of ladder bars with a leaf spring rear suspension requires that the rear end housing not be rigidly attached to the leaf spring. This is because the ladder bars and the front half of the leaf spring establish two different and competing centers of rotation for the axle housing. A floating housing mount eliminates the binding and allows the housing to rotate properly."
    I think you will find that the suspension will not flex very much at all, unless you accomodate the difference in the pivot points of the traction bar and leaf spring. /forums/images/graemlins/thinking.gif
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'll have to watch out for that bind thing, if mine bind up I'll let you know. On the other hand, since I could do over 800 on a 30* ramp with similar bars, I don't think I'll worry it. The only reason the rear stopped moving is the tire was hitting the side of the fenderwell really hard. The concept is sound.
  13. ben427
    Mar 10, 2002
    1,123
    Actually, as the spring compresses and the hackle moves rearward, the axle does too since the front is rigidly mounted and the main leaf must remain the same legnth. So in order for that to happen, the axle must move rearward until the spring is flat, then move forward when in negative arch. So the axle moves like this ) as the track bar tries to move like this ( . See what i mean??
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, that's not quite correct.
    If the traction bar is mounted in front of the axle, it will also want the axle to travel along the radius described by the bar length, pivoting at the forward mount. Problem is, the arcs are not exactly the same so you will get some bind. To minimize the bind, the length of the anti-wrap bar should be slightly less than the length of the spring from front eye center line to axle center line. This is due to the arc distortion due to the spring flattening making the effective radius of the axle arc smaller than it might seem.
  15. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    So your saying the shorter the bar the better. Currently these bars extend past the front spring mounts, but I do have shorter bars. Though I dont know if my brackets would still work.
    Another thing with the trac bar fighting the front spring mount, wouldn't the trac bar just force the axle to twist up/down slightly?
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No, it's not "the shorter the better" but rather "the closer the arcs the better". And yes, the binding would cause the axle to rotate, making the pinion angle change with suspension cycling. It will also bind in articulation. The amount of bind will be dependant on how the link angles and lengths work in combination. There are lots of things to consider... Using bushings rather than spherical rod ends will make things a more forgiving. As long as you are close in length you should be fine for the majority of users.
  17. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Stephen, if anyone is an expert in off-road suspensions, you are. I'm glad your set up works!!
    There are obviously differences in drag car and truck suspensions. My buddy and I fought this kind of binding on his '77 Firebird when we added ladder bars. His ET's actually dropped after the install because the rear suspension wouldn't compress enough to transfer the weight to the rear tires, even though we eliminated the wheel-hop.
    But I digress...we are talking trucks, not drag cars. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  18. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    mm hmm, we/ll see? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  19. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    ok big burban this is what you gotta do to make everyone happy go get on a ramp and measure your travel then install your traction bars and do it agin /forums/images/graemlins/thumb.gif
  20. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Yeah, I guess I can answer my own questions by doing it. Maybe even help you guys find out if my trac bar setup style works.
