Look what the Fabrication Fairy Left
Discussion in 'The Garage' started by Depdog, Dec 24, 2002.
  1. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Its rough, still have to clean and paint, and I am leaving it out to make a few copies of, will improve some things on the coppies. This is the proto type. Drivers side 350 Engine York Bracket. Bolts to the head and one brace to the intake.
    Depdog /forums/images/graemlins/grin.gif
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    /forums/images/graemlins/cool.gif
  3. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    cool /forums/images/graemlins/thumb.gif /forums/images/graemlins/cool.gif
  4. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
    multiple questions for you:
    1: Did you draw anything out wiht measurements? Are you planning on doing so, can I get the drawing from you?
    2: Do you think it possible to mirror partds and run them on the passenger side. I can only keep the K5 if it retains AC per the spousal unit, heck that's the only reason I was allowed to buy it
    3: I know there was one more but I can't remember what it was. time for bed
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Oh my goodness... I need to make a mount like that within the next month. If you have drawings or measurements, or would be willing to sell the plans or a complete mount, PLEASE let me know. /forums/images/graemlins/thumb.gif </font color>
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Oh yeah! An onboard air kit. I like it!
  7. Depdog
    1,657
    Georgia
    No drawings or measurments. I am trying to make a good working proto type first, then I will duplicate it. The duplicate will also have a few improvements. The brace on the proto type is welded on, it will be a bolt on brace on the 2nd go around. I was thinking about the mirror thing to make it work on the passenger side, I dont see why it would not work unless there is an issue with the manifold brace. If there is I should be able to come up with something else. This one also has a leg to attach the power steering pump bracket.
    As far as keeping A/C the on board air article on this site shows it adding a York with the factory a/c.
    Thanks for the comments.
    Depdog
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    My Yoks came with a BBC bracket that bolted it right on. I modified it to work on the small block and now I have to modify it back for the BB again! I found it in the junkyard on a chevy cube van.
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    so with this bracket how will the belt setup be? from the power steering pump to the york? I can't quite tell from the photo but how will tension be put on the belt does the york slide on this braket?
    great job Glenn it looks like yer putting a those FREE tools to work [flipoff]/forums/images/graemlins/grin.gif[flipoff]
  10. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Dep,
    If you need drawings, I can draw them in AutoCAD for you and provide you with files. Looks great - is that Stainless Steel? Can't tell from the pics.
  11. Grim-Reaper
    7,385
    Atlanta
    Nice work guy!. Now figure out how to mount one with the stock A/C still in there /forums/images/graemlins/smile.gif
    Here is a Christmas gift for you.
    http://members.cox.net/cglabe1/Air/OilFix.html
    Did AZ ship mine down there too? What do I owe you for shipping?
    Throw it in the truck when you run Rich and I get it from you.
  12. Depdog
    1,657
    Georgia
    The unit on the cube van was an aftermarket one. I looked at a couple of those and they ususally block the power steering resevior. The York I have came off a Fullsize wagoneer. It had a duel pully v belt clutch and I made the bracket to line up with the duel pulleys off of the power steering pump. One belt goes fromt he crank to the water pump to the steering pump. One belt goes all that way and then around the York. I have not gotten a new belt to check it yet. Soon as I do I will post some more pics. Raining here now (damn it, I wanted to finish)
    The York is mounted on another tray that slides inside the mounting tray, the slots are for 4 bolts to hold it in place. The tab on the bracket is for a bolt, as you tighten the bolt, it slides the york on its tray and tightens the belt. That way you dont have to have a pry bar and a bud to help hold it tight while you tighten the bolts that hold it.
    Did this make sense?
    Grim, I got that compressor from a Junk Yard, I have not heard anything else from AZ, have you?
    Are you going no the Jan 1 Ride, looks like Ken Braswell is bringing the Hybrid and there are about 10 to 12 of us if your going.
    Let me know.
    Depdog
  13. beater74
    May 29, 2001
    1,749
    atlanta
    Dep did you get your york from pull-a-part on morland? everytime i go there they have several volvoe's with the 10R yorks at a whopping $18.
    grim are you looking for a york? i got a spare one i'll sell ya
  14. Depdog
    1,657
    Georgia
    Nope, got it at the local place and it came off a fullsize Waggy. Might have to check out that pull a part yer talkin about though.
    Depdog
  15. Grim-Reaper
    7,385
    Atlanta
    Haven't heard from AZ. I'll drop him a line. Not in any real hurry. I have to get my exhaust redone before I can mount the PTO and it's going to be a while before I have the cash to do that. Just have to live with two rusted out mufflers and a bad colector flange till then. I want to put a set of those braided pipes in line near the engine. The collector flange was hosed because of the trucks frame flex. The pipe hits the transfer case and it puts some leverage on it. /forums/images/graemlins/tongue.gif
    Still in the air about Jan 1. At this point the people we were supose to go out with can't seem to get organized. Looking more like I might make it.
  16. Grim-Reaper
    7,385
    Atlanta
    Yeah I might be interested in that compressor. How much ya want for it? Does it have the port fitting with it?
  17. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Nice job Dep.
    I don't know if I want to use the York or a Sanden, I have both I was leaning to the Sanden Mostly cause I could get a mount for it from Alan Grove His prices are not bad, But I would rather support a fellow CK'er, So if you make them up Let me know.
    Eric
  18. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Lookin good....need to do the same without loosing my factory a/c. We took a spare compressor i had layin around the shop and fabricated it to run of the shop trucks start all.....works like a charm.
    Did you and grimy still want these compressors i have boxed up in the garage???
    Azblazer
  19. Depdog
    1,657
    Georgia
    Yes and Yes on the compressors, let us know how much and the shipping. Do they have clutches. Drop me an email and we will get it worked out.
    On the brackets, I am working on a couple.
    Depdog
  20. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Looks great.... I was looking for one about a year or so ago and gave up on finding something so I started finding the stuff to go to a stock type... Are you going to sell them after you make improvements?
