lookin for a tbi parts list..
Discussion in 'The Garage' started by k5redneck, Jan 11, 2005.
  1. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    what will i need to do a tbi swap into a 74 k5 with a th350? parts i have so far, the complete motor with all the sencors, computer, and all the motor wireing. do i need the dash wireing and cluster? does an 89 k5 have a speed sencor if so how do i get to work on my 74? any info will be a big help this is the first time that i done a efi swap before so im lost looking at it.:confused:
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Looks like you've got most of it. Get the speedo out of the cluster with the sensor and the little box that the sensor goes to. You can use your existing 74 cluster, with the new speedo and sensor/ amp for VSS. Grab the Park neutral switch off the column also
    Don't forget about the fuel lines up to the TBI, and the fuel pump/ tank with baffles if you go the in-tank pump route.
    For the O2 sensor, I just cut a hole in my existing exhaust, welded a nut on there, and put in a new sensor.
    P.S.- search on this, it's been done many times by alot of folks here.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'm just gathering parts to do my '78. Check out Painless Wirings web site. They have VSSs and other useful stuff. I'm using one of their looms as the stock loom I bought is way busy for what I need.
    This may be their address www.painlessperformance.com
