Looking at a Donor truck
Discussion in 'The Garage' started by BigCountryx, Jun 1, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I'm considering buying a Donor Truck to build my '90 K5. It's an '85 SRW 1Ton. D60/14FF 454/465/205 with a lift. What Parts could be swapped over? I know there would be issues with the BB and the 205, but could the lift be used?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    all swap easy including big block. 2 ways for rear axle. move mounts and reweld or use 1 ton hangers. plus shorten the shaft in the rear to fit k5.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Get rid of the K5 and keep the K30. The K30 is worth its weight in gold more than the K5.
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,851
    280
    Truckee, CA
    why not build the k30?
    Or shorten it and put the blazer body on?
  5. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    1. I want the extra seating so Reg Cab is out.
    2. Bent frame so K30 Frame is out.
    3. K30 cab is rotted to hell.
    4. Perfect for swap to by beloved K5.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Swap it all over. Even the hydro-boost. Just relocate the perches and mounts on the rearend to fit the K5 chassis and call it done.
  7. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    How would I go about swapping in the 454 and keeping the TBI? Would I have to get a new TB and injectors and the burn a new chip for the 'Puter or what? Will the Big Block bolt up to my 700r4?
  8. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    ttt
  9. Storm Trooper
    Nov 24, 2000
    4,640
    WOW! It's Wes,
    Glad to see you back.
    Sorry this has nothing to do with your post.
    Long time no hear from. Welcome
  10. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    ditch the 700r4, use the 465/205.
    You'd have to build the heck out of the 700r4 to make it live behind a 454.
    You already have all the linkages and pedals so use them.
