looking at an 82 burb, need advice
Discussion in 'The Garage' started by 1-bad-burb, May 12, 2006.
  1. 1-bad-burb
    1-bad-burb Registered Member
    Jun 23, 2005
    93
    west virginia
    ok so heres the deal, I found an 82 6.2 suburban, silverado, automatic, believe to be 135,xxx miles, now on a 82 could someone tell me what tranny/xfer case combo it would have? and would it be a 14Bff or a 14bsf? the price is $1700 and the body is great(no rust) except for a large dent in the rear passenger area, interior is decent, its all stock and has a switch for the glow plugs instead of the controller, its been sitting for a while and has not been started, the batterys were almost dead and it fired right up after about 10 seconds of glow time. and ran smooth as silk, no smoke just some steam when it fired up, what problems should I look for in a truck like this? I already have an 85 burb with a 6.2 thats thrown a rod, and now I'm looking at this one LOL
    Parker
    sorry if this is typed wrong but I'm looking for quick answers because I might brong this burb home with me today:D
  2. 1-bad-burb
    Jun 23, 2005
    93
    west virginia
    also, would it have an np208 or a 205? and it does have a vacum pump on the rear of the motor, so I guess its a TH400 tranny
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    unless it is an a/c truck, then it needs vacuum for the controls, look underneath on the passenger side ad see if it has a vacuum modulator, if it dosent it is probably a 700r4 or you can look on the dash indicator and see if it had overdrive on it, chances are it has a 208 with a 14bsf with a 10blt frontend
  4. 1-bad-burb
    Jun 23, 2005
    93
    west virginia
    its deffinatly a TH400, and the guy said its a 14BFF and I looked at the pumpkin, it looked larger then the one on my 14BSF, it does have a 10B front, now I jsut wonder what Xfer case it has? how can you tell a 208 from a 205:confused: ? I'll check tomorrow when I go look at the truck again.
  5. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    a 208 will have a tag on the rear facing side and its aluminum,a 205 will have the tag on the front facing side, 208 is a slip yoke and an 82 205 should be a fixed yoke.
