Looking at buying a 71 Jimmy 4x4..need some help!!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by maddog71, May 15, 2002.
  1. maddog71
    maddog71 Registered Member
    May 15, 2002
    10
    Hey
    I saw a 71 Jimmy in my area for sale. I am interested in the removeable top SUVs. What kind of things should I expect with this year of truck? Any common known problems? Is the removeable top include the door window frames? So there is just a windshield and thats it??? Any help would be greatly appreciated. Thanks!
    Maddog71
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The top including the window frame comes off leaving only the window (and roll bar if you have one). The main thing to look for is rust. The hardest to repair is around the window frame and the rocker boxes (a structual member under the doors...it is a 1' x 4' flat part when you look under the truck). The rear fiberglass hatch is also a spot to look out for. The rest of the drivetrain is standard Chevy stuff and easy to find. Check out some pics of mine at the links below. Mine is a '71 which means it came with disc brakes and the egg crate grill.
  3. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    <a target="_blank" href=http://coloradok5.com/forums/showthreaded.php?Cat=&amp;Board=firstgen&amp;Number=353731&amp;page=&amp;view=&amp;sb=&amp;o=>http://coloradok5.com/forums/showthreaded.php?Cat=&amp;Board=firstgen&amp;Number=353731&amp;page=&amp;view=&amp;sb=&amp;o=</a>
    A thread from a few months back which is pretty complete. Good luck
    JB
  4. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    Also - the frame where the steering box connects cracks - allot!. Check for this. I just bought a used truck and didn't know what to look for, turns out the frame is cracked in like 5 places up front (where the steering box mounts, where the front of drivers shakle mounts, and all around that area).
    Be careful. I am going to lose mucho denairo on my 69 thanks to not being careful.
    p.s. - anyone want to buy a beat up 69 withma strong motor?
