Looking at new rocker arms...
Discussion in 'The Garage' started by mouse, May 10, 2006.
  1. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Trying to decide between a couple of choices, but have no experience with them. Any opinions?
    Comp Cams stamped, roller tip
    Summit brand roller tip (I question the quality)
    Comp Cams aluminum, bearing fulcrum, roller tip
    Summit knock off of the above (same quality concerns)
    I guess I would like to know if the low prices on the Summit rockers are worth taking the risk. I'm looking for some 1.5 ratio rockers to use on 882 heads. The valve spring rate is only slightly higher than a stock spring and I'm using a Comp cam extreme energy cam.
  2. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I've used these with good results.
  3. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    I can't see any problems with quality and Comp cams...I probably won't take a chance with the Summit brand.
  4. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Depends on your wallet. Affordable, little less friction, longevity, go with comp. steel w/ roller tip. Got bucks ? go with the comp full roller. Even less friction/ heat but they wont last as long. ( some are rebuildable )
  5. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    x's 2, good rockers.
  6. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    X3 for me
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have the crane full roller aluminum rockers, no problems so far.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I would run the comp cams pro magnum full roller rockers, they can be had for about $250.00 or so. I've seen failures on the comp steel roller tip rockers so i wouldn't suggest them.
  9. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    That is looking good for the stamped roller tip. I don't mind the extra $$ for the full roller, but I want reliability and have heard a couple of issues with the aluminum rockers (not just comp cam).
    Anymore endorsements, or negative comments about the roller tip, stamped comp cam rockers before I buy?
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Look up, i've seen failures on the steel tip comp cams rockers. The ones i've seen fail have had the roller tip either break or come apart. The comp cams magnum full rollers are as light as the aluminums but they're made of steel and i've never seen a single failure yet. I've run them on an engine i used to have and have installed them on a bunch of engines i've built here at work with no issues.
  11. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
  12. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    OK, I see the difference now. I like those, and definitely want reliable.
