Looking for '85 to '90 Blazer
Discussion in 'Pacific Region' started by complexmar, Jul 23, 2003.
  1. complexmar
    complexmar Registered Member
    Jul 22, 2003
    52
    Tacoma, WA
    Looking for \'85 to \'90 Blazer
    /forums/images/graemlins/1zhelp.gif I'm drving a ford escort and it's seriously crimping my style. I'm looking for a decent blazer for a daily driver with some light wheeling on the side in the $2500-$4000 range. Have cash will travel /forums/images/graemlins/thumb.gif
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Re: Looking for \'85 to \'90 Blazer
    Welcome! /forums/images/graemlins/cool.gif
    Try buying a truck trader every Thursday (when they come out), usually a pretty good selection.
  3. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    Welcome to the board /forums/images/graemlins/smile.gif I will keep an eye out /forums/images/graemlins/k5.gif as I am just up the way in Fife.
  4. edeslaur1
    edeslaur1 1/2 ton status
    Jun 23, 2003
    193
    Oregon City, OR, 97045
    And, of course, there's always mine. /forums/images/graemlins/smile.gif
    It helps make lots of wheeling qualify as "light." LOL
    With some smaller road-rubber, it'd be an awesome daily driver. It used to be my daily driver for many years.
    http://coloradok5.com/forums/showflat.php?Cat=&Board=pnw&Number=797729&Forum=All_Forums&Words=14669&Match=Username&Searchpage=1&Limit=25&Old=allposts&Main=782692&Search=true#Post797729
  5. reedmit
    reedmit 1/2 ton status
    Feb 22, 2002
    207
    Oregon, Mount Angel
    What about a 79? I saw one for sale on my way home yesterday. It has a 454, auto, NP203 with part time kit. 2.5" lift with 32s. It is in Mount Angel, phone # is 503-845-6221 and he is asking 4,000. Blue and white, looked good from the road. I called the number for the info on it.
  6. complexmar
    Jul 22, 2003
    52
    Tacoma, WA
    Interesting, I shall give a call. Thank you /forums/images/graemlins/grin.gif
  7. complexmar
    Jul 22, 2003
    52
    Tacoma, WA
    So when I'm checking out a potential new K5, what types of things do I need to look for? Any insider info? I know that the rockers, and tailgate like to rust. Are there any places I can peek under the carpet without ripping it up? Or maybe give the 'ol Fonz jukebox tap to check to see if it's solid? /forums/images/graemlins/thinking.gif
    And as far as looking underneath. Any notorious leak spots, or tell-tail warning signs of trouble? (specifically the 350 and 700r4)
    Any buying tips would be appreciated. /forums/images/graemlins/pimp1.gif
  8. edeslaur1
    Jun 23, 2003
    193
    the tailgates like to rust, back bottom of the front fenders, top of the rear fenders.
    When subjected to hard wheeling/jumping, tranny cases can crack. Easy to spot from the trans fluid that will be leaking.
    700R4/208 combo - make sure all the braces are there. 2 from the bellhousing to the engine mounts, one from the tcase to the block. These were there as a fix to the above problem. The frame would flex, but the long engine/trans/tcase combo wouldn't and the trans case was the weak point. Model K trans cases are thicker walled to help with this. You can tell these because they come w/ a cast flywheel cover (vs a tin cover). 70s trucks won't have the braces that I'm aware of.
    Obviously, look for any leaks.
    Check the frame at the steering box for cracks. Chevs are notorious for cracking there. Very common - so common, about 100 companies make a fix for it.
    If dual front shocks, check at the shock mounts for cracks. More people than should replace a paired set of shocks w/ 2 indiv shocks and cause the frame to crack or break there due to the stress of 2 shocks acting like 2 shocks instead of a paired set acting like one shock.
    If the tcase is dropped, make sure it fully engages 4Lo. No use stripping the 4Lo gears due to partial engagement (may also pop out of 4Lo due to this or trashed shift forks).
    I have to run to a pool party /forums/images/graemlins/laugh.gif right now I'm told (bikinis bikinis bikinis!!), so I'll post more as it comes to mind. This should be the major parts. /forums/images/graemlins/thumb.gif
