Looking for a Cummins 3.9BT specific forum, Help!
Discussion in '1982-Present GM Diesel' started by grimjaw, Jan 27, 2006.
  1. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I am looking for a Cummins 3.9BT specific forum. ANyone know of a good one? I am getting comparison info together for different diesel options. Thanks.
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Whar are you doing the research for?
    I haven't found a 3.9 specific forum but I know of a couple of guys that have it in their K5 and they say it works great.
  3. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I am comparing the cost, reliability, possible power, fuel economy and ease of swap between the GM 6.2 -6.5 and Cummins 3.9BTs.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    look for the 4bt group on yahoo, there are a few of us on there
  5. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    I have that group. I am just looking to see if there is any more places to get info.
    Thanks.
    It would help if there was a program like Desktop Dyno for Diesels.
  6. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    Cummins 3.9
    What info do you need ,I can help with the parts I have a complete P 30 .
    ask away.
    3.9 can get up to 25 mpg with good power,say 300HP
    A 6.2 or 6.5 can't come close and won't last as long .
    (My bother is doing a 3.9 in his 84 Blazer,he just getting parts together ).
    P.S my shop is moving to knoxville, TN
    CrewCab59
  7. BowtieBlazer
    Jul 15, 2001
    2,462
    crawlink5 on this site just finished his conversion in a 79 blazer, we got it on the road yesterday.
    I'm going to be dry fitting mine with the body on soon as well in my 86
    here is a dyno curve on the 4bt.
    Ease of swap obviously goes to the 6.2 or 6.5 as they are straight bolt ins.....
    here is a pretty good 6.2 build
    http://community.webshots.com/album/286393940AoOzqp
  8. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    I certainly like the engine! If I can just get my brakes working...
  9. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    To hijack my own thread....Hydroboost brakes are your friend.
    I am interested in what is needed to get 240+hp 450+tq and keep 25+mpg. Is this using comman parts or do you need that rare, only made 30 years ago, part?
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    Yes indeed
    Basically turning up the fuel pump starts barking out the tq and HP, however that starts = fuel mileage loss, I'll have to find the spec sheets I had printed, I believe the 4bt that I saw with simillar numbers to what you posted was down in the teens on mileage. Still beating a gas motor though.
    You can also look at interchanging turbos with a 6bt for a quicker spool and more low range pep, they make higher flow injectors, pumps, etc etc......by no means is the block, internals, or compression a limiting factor.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    What type of injection pump is on these 3.9's? Are they rotaries like the VE 5.9's or are they inline pumps like the P7100 on the P series?
    If it's an inline bosch pump you could maybe modify the fuel plate for more fuel just like the 12v 5.9's are capable of.
    An HY35 quick spool turbo like what is on my '01 Ram auto would work perfect on the 3.9. the HY is good for basically 300HP and spools quick. The HY doesn't leave much room for fuel on the 5.9's and you could pick up an HY for cheap because of that reason, they get tossed if you want to make more than 300HP and actually tow at the same time.
  12. BowtieBlazer
    Jul 15, 2001
    2,462
    its a rotary pump on the 3.9's the inline ones for the 4BT are $$$$$$$$
