Looking for a measurement......
Discussion in 'The Garage' started by jimmyjack, May 1, 2004.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    The front spring rear shackle is all wobbled out, about a 1/2" on top and bottom holes. I'm gonna make some up out of some flat steel I have laying around. Anyway, does anyone know the center to center length. Is it real exact, or can I fudge a little bit?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I think it is 4 3/4" or 5" but you can extend that if you want. I have 1/2" over stock. Gives 1/4" lift. I know people that run 1" over stock too. It can mess with your pinion angle if you extend it too much.
    Harley
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Now THAT'S what I'm talking about! I haven't removed mine yet, but I can see the spaces in the shackles. I'm gonna keep it stock, the front and back are damn near equal in height. On a side note, the guys from WheelingArizona are gonna head to Florence next weekend.(if your still in town)
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am living in Phoenix again so I will be here. I am going to Table Mesa for a test run tomorrow. I might be up for next weekend. We will see. I will go check it out and see what they are going to run.
    Also when you make new shackles use 3/8" plate and if you can upgrade to 1/2" bolts. You will need new budhing and sleeves but it is worth it. 7/16's snap easy. AZK5 snapped 2 in one trip.
    Harley
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    stock are 4" and the ORD are 4.5" if you lifted it alittle i would go with the 4.5" or at least 4.25". keeps the spring from hitting the frame /forums/images/graemlins/waytogo.gif
